Running rough
Old Aug 30, 2010 | 09:04 PM
jmaxe444's Avatar
jmaxe444
Running rough
Hey guys, I was on my way into town today and I noticed that my truck was running rough. The tach. was moving up and down while sitting at a stop and then when I stepped on the accellerator there was a hesitation and delay in the truck going. Any ideas? The truck is an 05 6.0 diesel with about 73k on the odo. and it is stock. Thanks in advance.
Old Aug 30, 2010 | 09:13 PM
bismic's Avatar
bismic
When was it purchased (maybe still under warranty)?
Old Aug 30, 2010 | 09:14 PM
amadas350's Avatar
amadas350
any smoke at idle or during acceleration?
Old Aug 31, 2010 | 06:32 AM
CAMPINGTOM's Avatar
CAMPINGTOM
Mine has done this intermittently for the last few years. I can't figure it out.
It will not do it for 1000 + miles after an oil change. But as the oil gets some miles on it, it starts doing it again.
Old Sep 1, 2010 | 09:38 PM
jmaxe444's Avatar
jmaxe444
No smoke, but today it would not start back after turning it off at a store. I had it towed to the house and charged up the batteries and it started up then after it warmed up I tried to restart it and it just cranked but did not start. I had this problem about 18 months ago when it was still under warranty and it was an oring or something. When the motor cools down it starts right up.
Old Sep 6, 2010 | 11:04 AM
jmaxe444's Avatar
jmaxe444
ICP sensor was the problem. Changed the plug for it as well.
Old Sep 6, 2010 | 01:55 PM
69cj's Avatar
69cj
Disconnect the ICP if it still doesn't start there's a good chance it's the stc fitting in the hpop system. If it starts, icp sensor again but doubtful.
Old Sep 6, 2010 | 04:39 PM
rockstar69's Avatar
rockstar69
NEWBE to the ford form 2003 f250d starting problems
f250 6.0 2003...97,000k.....where do i start.I replaced my icp about 4 months.Ran good for about 2 months.started running ruff.(no code) start running injector cleaner.(no change) it has been running ruff now for 2 months at a speed of 45 to 55.Over that runs fine,under that runs fine.Still no code.Now it will not start.
does any one have any ideas?????
Old Sep 6, 2010 | 05:18 PM
69cj's Avatar
69cj
Did you also replace the connector plug?
Old Sep 6, 2010 | 10:50 PM
rockstar69's Avatar
rockstar69
running ruff
No i did not change the plug.It looked good.It was not oil socked.I did wrap the plug with elec tape to make it stiff enough to plug it back in.Have you had trouble with the plugs.I did give it a boost of WD 40 and starting fuild.i let run for about 15min.Stop it from running. it started right up. I now have code light. will take it in tomorrow to read the code.my brick scaner , i do not have the soft ware to read diesels.
Old Sep 7, 2010 | 09:07 AM
69cj's Avatar
69cj
Just for your info, starting fluid is a big no-no on diesels.
Old Sep 7, 2010 | 09:55 AM
rockstar69's Avatar
rockstar69
running ruff
Thanks.Yes you are right.That was the ownly way i could get it started.WD40 is what you want to use,lot safer.I will post what code it is.On that plug.Have you had problems with yours?
Old Sep 7, 2010 | 10:02 AM
69cj's Avatar
69cj
No I haven't but a lot of people have, esp. on the early icp's behind the turbo.
Old Sep 7, 2010 | 10:50 AM
rockstar69's Avatar
rockstar69
running ruff
I will look into replaceing that plug.It is about $20 bucks.Ford lays you away on that ICP,no after market.With that ICP under the Y pipe or next to the turbo.bad design.I have not had any trouble with my 6.0,until the last 6 months.I do have a question.I have been looking for good replacement fuel filter other than ford.At a good price.I have been buying fram set at $63 bucks.I have oil filters dieled at $11.02 apeice.
Old Sep 7, 2010 | 11:06 AM
bismic's Avatar
bismic
Personally I don't use Fram fuel filters. Some folks have shown that Fram oil filters are OEM, but then others have seen Fram filters that are not the proper design. Who knows, but to avoid any question, I do the following:
Get your fuel and oil filters from Dieselfiltersonline or at an International dealership. Lots of documentation showing aftermarket filters cause BIG problems. Use only Racor (OEM manufacturer), International, or Motorcraft filters.
Many people ignore this advice and then have problems. Few of them can swallow the pill that they created the issues.
