Need some help please
Old Aug 30, 2010 | 08:35 PM
rrob's Avatar
rrob
I have a 61 Econoline pick up and need some parts and serial help. Looking for a source for king pins and a new master brake cylinder. I am also looking for the **** that goes on the driver's door window regulator. It is at the end of the arm and goes into the track for raising and lowering the window glass. I would also appreciate help in deciphering my vin. The tag shows F10SH123287, 090M, F100, A. 01, 3300, 074, 4000.
Thank you for any help!
Old Aug 31, 2010 | 07:39 PM
rrob's Avatar
rrob
FYI I found a source for the king pins and the master brake cylinder. I would appreciate hep in deciphering my door tag please. Thank you.
Old Sep 10, 2010 | 09:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by rrob
I am looking for the window roller that goes on the drivers door window regulator. I would also appreciate help in deciphering my vin.
The tag shows F 10SH123287 / 090 / M / F100 / A / 01 / 3300 / 074 / 4000.
Welcome to FTE
Take a closer look at the Warranty Plate, some of the codes you listed are for an F100 2WD. You originally combined the W.B. (wheelbase) with the COLOR code (090M).
F should be E ~ E10 = Econoline Pickup.
S = 144 1V 1-6.
H = Lorain OH Assembly Plant.
123287 = 1961, assembled Decembler 1960.
090 = 90" Wheelbase.
M = Corinthian White.
F should be E ~ E100 = Econoline Pickup, 3,000 lbs. GVWR
A = Ford 3 Speed Light Duty Manual Transmission.
01 = Ford 7 1/4" Rear Axle / 3.50-1 / non Limited Slip / 2,300 lb. Rear Axle Capacity.
3,300 lbs. Gross Vehicle Weight Rating.
74 net HP @ 4,000 RPM
COAB6423240B .. Window Roller / Obsolete
Fits: Myriad 1960's Passenger Cars; Trucks; Bronco's & Econolines.
At one time every autoparts store carried this puppy, suggest you try NAPA or an indie parts store. Ask for one for a 1961/74 Econoline, 1965/66 Mustang, or 1966/77 Bronco...same-o same-o.
Old Sep 12, 2010 | 09:18 PM
rrob's Avatar
rrob
Thank you for responding, I really appreciate it! My truck came out of a small salvage yard in northern Minnesota and is acually in very nice shape. It was, I believe, used by a utility company as it was painted orange from the level of the bed on down. The odometer shows 24,xxx so I guess it has another 100k on it. Fun to drive, lots of lookers.
trainmuzik
Mar 14, 2013 09:33 PM
tiger_698
Jul 5, 2011 02:39 PM
r2000f150
Jul 5, 2010 10:37 AM
smallblock351w
Appearance & Dress-Up
23
Dec 13, 2006 07:33 PM
hirschi
Jun 30, 2002 01:51 PM
