Fuel Line Quick Disconnect
Old Aug 30, 2010 | 03:02 PM
linckeil's Avatar
linckeil
1996 F350 SRW, regular cab, 4x4 with 351 motor and dual tanks.
the fuel lines run on the driver frame rail. directly under the rear of the cab sits the inline fuel filter on the SUPPLY line. directly below the filter is the quick disconnect on the stainless steel RETURN line.
i disconnected the RETURN line at this fitting and when i did, 4 things dropped out of the female end of the quick disconnect. They are: a steel sleeve (ring), a plastic sleeve (ring), a black rubber O-ring, and a blue rubber O-ring.
Now these parts shouldn't have come out, but they did. I'm not sure I collected everything, but i think i did and I have no idea what order they are supposed to go back in. Does anyone have an exploded view of this fitting and these parts? Any idea why these parts would have fallen out?
i've disconnected lots and lots of Ford fuel lines and have never had anything like this happen. can anyone help?? thanks.
Old Aug 31, 2010 | 05:02 AM
jarod17's Avatar
jarod17
The Ford Shop Manual was no help here It states " Fuel tube should be replaced if internal parts are damaged. " This does not make sense to me because when I was shown how to do these fittings, the mechanic stated that if the inside parts get damaged they can be replaced. You could try at your local parts store and see if they have the internals. If so they may have a diagram as well. Another place to try might be from a Ford dealership.
If you have already thought of, and tried this, I am out of ideas.
Old Aug 31, 2010 | 09:22 AM
linckeil's Avatar
linckeil
thanks for the reply. are you still in touch with the mechanic you mentioned that said the parts can be replaced? maybe he has some ideas.
no local parts stores were of help. i went to one ford dealer and they were worthless. a second i went to were much more compentent, but have never come across this issue. there are 2 other dealers i'm going to try.
and a new line is about $400 bucks - i like the idea of replacing the O-rings a lot better (if possible)
Old Sep 1, 2010 | 09:57 AM
jarod17's Avatar
jarod17
When I get into town I will see what he says.
Old Sep 2, 2010 | 08:14 AM
linckeil's Avatar
linckeil
i messed around with it last night. looking at other disconnect ends in the fuel system, i took a stab at how it might go back together.
i slid the 4 pieces over the male end. first the metal sleeve, followed by the plastic sleeve, followed by the blue O ring, then the black O ring. i then attempted to connect the line and it snapped right into place. i ran the motor at idle for about 5 minutes and keep a close eye on it - not a drop. i then wrapped the connection in a papertowel and went for a 15 minute ride. i got home, removed the paper towel, and not a spot on it - not even a smell of fuel.
so i think i got it taken care of. maybe this thread can help someone out in the future that comes across this odd occurance.
asavage
Aerostar
Jun 17, 2021 01:59 PM
ron's power stroke
20
Dec 8, 2011 02:11 PM
Coccyx
Aug 2, 2010 12:53 PM
empireweld
Feb 13, 2010 05:10 PM
ctann
Oct 26, 2009 06:57 PM
