5-speed swap
Old Aug 30, 2010 | 11:29 AM
clems78's Avatar
clems78
5-speed swap
i want to swap a 5-speed into my 78 2wd camper special 400m it is a 4- speed now the truck is all stock with 70,000 on it but when my grandpa still had it he let people use it and they killed third gear so if it needs to come out i want a 5 gear i will someday be putting a cummins in it but for now i want the 5 gear any help would be awesome thanks
Old Aug 30, 2010 | 12:21 PM
doug70's Avatar
doug70
nv4500
If you plan a cummins in the future, get a NV4500 now and re-use it later.
Doug
Old Aug 30, 2010 | 01:04 PM
clems78's Avatar
clems78
dodge truck trans? how close will the hole be to the factory one?
Old Aug 30, 2010 | 01:18 PM
doug70's Avatar
doug70
not at all
The holes won't line up. If you look closely you will see an adapter between the trans and bell housing. Mine is from Advance adapters 1-800-350-2223. Works fine.
Doug
Old Aug 30, 2010 | 03:39 PM
clems78's Avatar
clems78
how much was yours? what about the hole in the floor? what clutch do you use?
Old Aug 31, 2010 | 12:03 AM
clems78's Avatar
clems78
i found one from a chevy it is behind a 6.5 td will it work for this swap?
Old Sep 10, 2010 | 05:49 PM
clems78's Avatar
clems78
cummins swap is out for this one i found a super cab so this one just needs a easy 5 speed swap
Old Sep 10, 2010 | 07:59 PM
garypettengill's Avatar
garypettengill
Ford Zf5 from a 460 truck. Not the easiest swap but then no other is either. Search this site and you'll find threads concerning this. I have one on the floor in my garage for a swap this winter.
Old Sep 11, 2010 | 07:36 AM
doug70's Avatar
doug70
nv4500
The adapter for the Nv4500 swap is about $440 or so. It works for 1995 and later GM trans. I think it works for all Dodge trans. I had 2 of these around for different projects, one was a 93 and wouldn't work and the other was a 95 so I used it.
I haven't put the cab on it yet so I don't know how different the holes are, but have read posts here that there is a difference.
I just got the motor back and installed with the trans last week.
Doug
knuckleharley
Dec 20, 2006 08:04 AM
rotory.1
Dec 3, 2004 10:05 PM
RJMACKY
Sep 14, 2004 12:27 PM
Crowbar65
Feb 12, 2003 11:09 AM
chris78green
Feb 26, 2001 12:10 PM
