Turbo Question
Old Aug 30, 2010 | 10:11 AM
Dennis87-91's Avatar
Dennis87-91
Turbo Question
Im looking to turbo my 1990 f250 7.3 but i dont want to spend 2000-3000 dollars on the turbo kit. Im seeing on ebay and in the scrap yards people selling the turbo kits off the 93-94 turbo engines pre powerstroke. Would this be a good choice or would i be wasting time?
Old Aug 30, 2010 | 10:19 AM
greywynd's Avatar
greywynd
Do some searching and reading on here. As long as it is pre-powerstroke, and you get ALL the parts, it's the most economical way to turbo an IDI. (Exhaust piping, valve cover, CDR relocating bracket, turbo pedestal, turbo, oil lines, air intake hat and filter housing....what else did I miss guys?)
Old Aug 30, 2010 | 10:46 AM
oreocreaming's Avatar
oreocreaming
there is one on there now, Ford ATS factory turbo kit 7.3 6.9 idi diesel: eBay Motors (item 220659127181 end time Aug-30-10 15:45:38 PDT)
you got 7 hours. its got everything.
greywynd, you got it all minus the second valve cover. you need drivers side for the cdr valve hole and you need the passenger side for the glow plug controller bracket. but you need to specify the exhaust. its a cross over pipe that goes from the drivers side to the up pipe, you need the 2 piece up pipe that bolts straight to the passenger side manifold and you need the downpipe. you dont need new exhaust manifolds, they are the exact same as the ones you have now.
Old Aug 30, 2010 | 11:26 AM
Dennis87-91
so you guys say it is worth it i know they didnt have the 250hp or 275 hp as the powerstroke but its gotta be better than the 180hp and 380ft lbs im making now right?
Old Aug 30, 2010 | 11:56 AM
oreocreaming
depends on what your gonna do with it. Turbo only helps if you tow or druve semi steep hills. Flat land and saily driving you won't notice any gain. It's not until your egt's get high that it starts to spool
Old Aug 30, 2010 | 11:57 AM
NorthernDiesel's Avatar
NorthernDiesel
PM me, I've got the whole deal minus the rocker cover, swapped it all out for my Banks kit. The Banks kit locates the CDR on the turbo intake, but since I had factory turbo I had to plug the valve cover to make the Banks setup. All in Canada though!
Old Aug 30, 2010 | 11:59 AM
Dennis87-91
Yeah i use it to tow the dirt cars and it doesnt like pulling the race cars its got plenty of take off but after 2000 it totally dies
Old Aug 30, 2010 | 05:05 PM
greywynd's Avatar
greywynd
Hey ND, gonna send you a PM! I thought of the second valve cover, but that one isn't the end of the world, just recently someone posted a pic of a bracket mounted GP controller because they didn't have the right valve cover. As far as the driver's side cover, is it possible to modify a stock one? I know it needs a hole for the CDR grommet, is there a baffle or anything inside it to prevent oil splash going up into the CDR, or is it just open?
I suspect that there could be a lot of turbo's out there without the right valve covers, but it would be a shame to not be able to use one because of it.
Last edited by greywynd; Aug 30, 2010 at 05:11 PM. Reason: Added valve cover info/questions.
Old Aug 30, 2010 | 08:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
There is a splash guard under the CDR opening in the rocker cover on the ATS 093 version.
The stock Ford turbo is a carbon copy of the ATS 093 except for the turbo outlet flange and downpipe.
PS the 94 Strokes had 215 HP
95 and 96 had 225 HP
97 had 235 HP
A well tuned IDI turbo can run with or in front of any of those years unless they have mods done.
Old Aug 30, 2010 | 10:15 PM
George D.'s Avatar
George D.
Oreo somethins wrong with your truck myturbo sppols quick and I see boost running around town though not impressive amounts if I'm just putting around but its more air than I would have NA
Old Aug 30, 2010 | 10:18 PM
greywynd's Avatar
greywynd
So it would be possible with some hole creating, and baffle fabricating to modify a set of stock covers to work. Cool, glad I have an extra pair or two around here!
Old Aug 30, 2010 | 10:23 PM
oreocreaming
i just got it rebuilt and havent gotten a chance to drive it yet. i know before i had it done i wouldnt get any boost until there was a load behind it.
Dave Sponaugle
I don't see why you couldn't.
I also have boost at in town speeds.
Big difference from NA by 1500 RPM.
Old Aug 31, 2010 | 12:34 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I agree with everyone else, I can tell a big difference between my 6.9L and my Factory Turbo '94 at all times/anytime.
My stock '94 IDI Turbo is noticeably quicker than my '95 slightly moded and '97 stock PowerStrokes. I think it's mostly because the PS doesn't have a waste gate turbo.
My '95 might be a little better at pulling wieght up hill than the '94 but it's hard to tell without having them side-by-side, equally loaded.
Old Aug 31, 2010 | 06:17 AM
NorthernDiesel
For those wondering what the valve cover mods look like on factory turbos:
(These came from the Ford manual for the IDI turbo mods)
Driver's Side Rocker Cover - Topside (CDR Mount)
Driver's Side Rocker Cover - Down Below (Oil Baffle)
Passenger's Side Rocker Cover (GP Controller Bracket)
