1978 - 1996 Big Bronco
Bare Minimum Wireing
Old Aug 29, 2010 | 04:49 PM
redhawk41's Avatar
redhawk41
I have an 82 Bronco that has 3 wireing harnesses in it. The POs have used parts of all 3. As you can imagine I have lots of shorts and problems with it. Does anyone have a bare Minimum wireing diagram of only the wires I need to make the motor run? This is an offroad only toy and I want something as simple as possible to trouble shoot on the trail. I want to run everything with simple toggle switches (no keys just toggles and push button starter).
Old Aug 29, 2010 | 11:49 PM
greystreak92's Avatar
greystreak92
The harness information in a Haynes service manual should be all you will need to cull together the wiring "required" to run the truck.
Old Aug 30, 2010 | 01:01 PM
hillbilly469's Avatar
hillbilly469
If you get a Chevy style one wire distributer for your ford you can do away with almost all the wiring. You still need the solenoid and wires going to the starter, a push button starter switch could then be used, the alternator can be switched to a one wire chevy style, and everything else can go to the trash. I wouldn't do it quite this way for a street vehicle but you could.
Old Aug 30, 2010 | 02:18 PM
fatboyf150's Avatar
fatboyf150
for simple troubleshooting in an offroad rig, this guy is on the money. here is the distributor you need White Performance Detail Description we have used quite a few of these in offoad rigs and are top of the line for the price.
Old Aug 30, 2010 | 03:27 PM
redhawk41's Avatar
redhawk41
Thanks for the info
Thank you both for the information. Does anyone know of a GM one wire alternator that will bolt up in the place of the stock one for a 351w?
Old Sep 3, 2010 | 09:04 AM
hillbilly469
Any Chevy atlernator in the 70's or 80's will give you what you want thought you may need to modify the mounting bracket a little with spacers but its a pretty easy mod. The best bet is to pick on up at a scrap yard for $20 in my opinion.
Old Sep 9, 2010 | 08:31 AM
redhawk41's Avatar
redhawk41
I just got done wiring in a one wire alternator. I only has one wire that goes to the battery. After about 6 months trying to get all the rats nest of wires sorted out this was very easy and cheaper than completely rewiring the entire vehicle
Old Sep 9, 2010 | 10:53 PM
cOpE!'s Avatar
cOpE!
Amen to all of that...I run my bronco on the street as well as off road and I went to a one wire HEI dizzy and altenator. BEST move I EVER made.
1eyedjack
Electrical Systems/Wiring
Oct 19, 2012 04:16 PM
mini_blaine
26
Dec 7, 2011 12:43 PM
Huntersbo
Mar 19, 2011 08:28 PM
79 bronc
Dec 5, 2005 02:52 PM
