Body mounts
Old Aug 31, 2010 | 08:18 PM
78ford351m's Avatar
78ford351m
where at on the bed? I don't recall one???
Old Aug 31, 2010 | 09:13 PM
mudder460's Avatar
mudder460
There are no bushings under the bed, it is just 8 bolts that hold the bed down to the frame.
Old Sep 1, 2010 | 07:25 PM
bmarkline's Avatar
bmarkline
Yeah re-read my last post, when I said about bed body mounts I was refering to a Bronco as I had stated. Sorry if I confused anyone.
Old Sep 1, 2010 | 09:44 PM
Dskeet6's Avatar
Dskeet6
i have the energy suspension kit lying around.... whats the best way to go about installing?
Old Sep 2, 2010 | 07:30 PM
bmarkline's Avatar
bmarkline
You install them the same as you would a stock piece. The way I do it is loosen all hardware, then lift up one side at a time on the body. Replace all the bushings on that side, just starting the hardware. Do not tighten any hardware until you have all mounts replaced and make sure everything is square on the frame. Then tighten them down. If the old sleeves are rusted together, then your sorta screwed. I've always had to cut them off and replace them.
mwacosta$
Feb 26, 2021 06:34 AM
BAJI26
Jun 16, 2015 08:17 AM
racenitro
Feb 19, 2015 10:24 AM
gdirwin
Jan 12, 2015 07:47 PM
chesire17201
Sep 25, 2012 07:41 AM
