Steering issues
Old Aug 28, 2010 | 08:29 PM
tuke's Avatar
tuke
Steering issues
Alright all you front end gurus I have some issues with my 92 4x2 steering. I have basically replaced every component on the front end, steering box, tie rods, drag link, radius arm bushings, Have the pivot bushings just not installed yet. Problem is wandering while driving. Get a good 1/4 turn each way while driving and its quite annoying I adjusted steering box to eliminate play their. Had a helper turn wheel to and fro while I observed movement of components on the front end but everything looks tight as it should any help appreciated. Thanks Ed
Old Aug 31, 2010 | 04:40 PM
bobbyjo9's Avatar
bobbyjo9
How bout slop between the two shafts? I noticed play in the slip joint and made 2 shims to slip between them under the rubber cap. Felt like i was steering with a rubber band before and have no play after
Old Sep 1, 2010 | 08:56 AM
DBGrif91's Avatar
DBGrif91
I can't remember the exact problem, but I remember a similar thread a few weeks ago. I think it turned out to be a problem with the rear suspension. I just tried searching but couldn't find it. Maybe someone who does can provide the link.
BrokeLoser
Nov 17, 2014 11:01 PM
KilBox
Jun 12, 2013 06:01 AM
Talyn
23
Oct 22, 2012 05:21 PM
84ford150
Apr 28, 2008 06:15 PM
sfd4
Jan 9, 2006 07:23 PM
