Any tips on removing the whole filter housing. When Ford built this the hose clamp(bottom hose) is upside down and can't get to it without removing the whole housing.
If you are referring to the blue fuel lines they normally get replaced, just cut them.
IH Ford makes a kit.
International 1823587C91 Kit Fuel Hose, BLUE
(Ford) F4TZ-9324-CA, 3" Long lift pump to filter inlet
(Ford) F4TZ-9324-DA Shorter than above, Filter outlet to High Pressure (piston) pump inlet.
Aftermarket hose = Aeroquip FC498-06
Thanks
I have the hoses but the one on the bottom had the clamp facing down . Only way to get it was to remove the filter housing(I figured it out).
Now that I have it out I found sand and other trash in bottom so a rebuild is likely.
