Wiring problems
Old Feb 17, 2003 | 02:39 PM
moewaltner's Avatar
moewaltner
Unhappy Wiring problems
Hi guys I hope someone out there can help! I am putting a cab on my 77 f-250 4x4. In the process I decided that I wanted cruise and tilt steering, which I had in a 78 bronco for parts. The problem lies within the wiring harness for the bronco. It does not have the wires for dual tanks, or the hook ups for putting that part of the harness from the pickup in. Anyone ever messed with this before? Do you know of any wiring diagrams I can down load. And finally Do you think there are any more hidden problems? Thanks Moe
I should add that the cab is a 76 2wd and I have taken the wiring harness out and replaced it with a harness out of a 78 bronco. I wanted the tilt,cruise and air!!!!
Old Feb 17, 2003 | 02:46 PM
Mil1ion's Avatar
Mil1ion
Wiring problems
The wiring harness on the column is the same for both columns with the T/S switch being different between the Tilt & Non-Tilt.
You need the cruise wiring which allows the horn circuit from non-cruise to turn the harness into cruise.
The includes the new horn circuit with relay,wiring to cruise control amplifier.
I made up a complete list to swap in cruise in a non-cruise truck if you're interested?
Old Feb 17, 2003 | 04:08 PM
moewaltner's Avatar
moewaltner
Wiring problems
Thanks Dennis ! I knew I could count on you. I do have all the parts that I need for the cruise. I dont have the hook ups for the tank selector switch by the temp control. The bronco harness had a rear window switch. I took the plug off the pickup harness and it has the brown/white wire for the selector valve but not the orange wires for the fuel gauges. This is were I am stumped!!!
Thanks for the help! Moe
Old Feb 17, 2003 | 04:20 PM
Mil1ion's Avatar
Mil1ion
Wiring problems
I have a dual-tank switch but the harness you will have to get from a truck with that option.
I don't have the harness, so I can't tell what all goes with it.
Do you have access to one?
Old Feb 17, 2003 | 05:45 PM
moewaltner's Avatar
moewaltner
Wiring problems
Dennis
I am afraid that it is a part of the main harness. There is a smaller harness that the plug end for the switch is connected to. This then plugs into the main harness. If you know the whereabouts of a harness or someone that has one let me know. This is what I think that I need---- A harness out of a 78 or 79 with cruise and A/C with factory dual tanks. Oh did you say that you can use the harness out of a pickup that does not have cruise and add it in? If that is an option I could use the harness out of the 76 that was in the cab. I cant tell you how much your help means to me! Thanks Moe
Old Feb 17, 2003 | 07:36 PM
Mil1ion's Avatar
Mil1ion
Wiring problems
Correct.
Okay!
Will Do.
The cruise harness is an add-on from a regular harness
and A/C
part of 14441 harness
I have to check for with or without 14441 harness
Me use it ? No!.
A person who wants to add cruise control to a non-cruise truck can do so by an adding on the special harnesses
There are two harnesses that go from the underhood to the underdash to operate the cruise control
I thought you said you had all the parts you needed?
(How about Special Brake booster & Brake pedal assembly ?)
I can't tell you how much your help means to me!
Thanks Moe
69issofine
Feb 2, 2015 09:02 PM
highoctane74
Jun 18, 2013 10:11 PM
Ruo1630
Mar 3, 2007 09:29 PM
just1me
19
Jun 20, 2006 01:03 AM
heybrent
1978 - 1996 Big Bronco
Mar 20, 2001 08:20 PM
