Slow to crank
Old Aug 28, 2010 | 12:27 PM
GT_350's Avatar
GT_350
Slow to crank
Morning fellow psder's
ok here's the deal.
Here a few days ago, had been driving the truck around all day.
Came home, then a few hr's later went to start the truck, and it's like trying to start it with a 6v batt, cranked slow.
Checked the alt with a fluke 77 multmeter get 14.92v
Batts checked out at 12.66 this morning before starting.
I did notice that when I turn on the key, before the wait to start light goes out I hear a click & the batt light blinks then the start light goes out.
Everytime this happen is when the slow crank occur's
These does not happen all the time just when it's been sitting for more then a few hrs.
Now 2 days before I installed a brake controller using the same wire's that the previous owner's had used. I also installed a trailer wire harness
part #755-1556.
I checked the fueses and in the fues box under the hood the 30a fues in SUD 4 is blown not sure what it goes to, havn't found my book for the truck yet lol
If anyone has some direction on where to start looking it would be greatly appreciated .
Thanks for your time again
Eric
Old Aug 28, 2010 | 01:02 PM
DRRXR's Avatar
DRRXR
If I am not mistaken #4 under the hood should be a 25 amp fuse for Trailer Marker Lamps Relay. Trailer backup Lamps Relay
Old Aug 28, 2010 | 01:17 PM
GT_350's Avatar
GT_350
Thanks rocky, good to know cause i'm about to hook up the trailer today.
in my post I talked about the clicking sound. I found out that it's coming from the solenoid just to the left of the fuel filter.
Is that for my glow plugs? cause when that clicks loud is when it will slow crank.
Is it going bad or is the glow plugs bad and making the solenoid work wrong?
Old Aug 28, 2010 | 03:07 PM
95PSDieselP's Avatar
95PSDieselP
that is your glow plug relay....
Old Aug 28, 2010 | 03:39 PM
DRRXR's Avatar
DRRXR
This should help you figure out the if the gpr is bad
Welcome to guzzle's Stancor GPR replacement Mod Web Page
and
https://www.ford-trucks.com/forums/6...upgrade-3.html
Old Aug 29, 2010 | 12:45 AM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
I was experiencing a slow cranking problem last year. It turned out to be a bad starter. I even checked the amp draw, I don't remember the exact numbers but it was within specs.
I replaced the starter after several days of debate with myself and it has been cranking a starting just fine ever sense.
Old Aug 29, 2010 | 10:17 AM
GT_350's Avatar
GT_350
Hey tim
I saw that another guy had the same issue.
so far all I have replaced is the GPR cause the old one was clicking louder then I thought it should. I'm gonna check and make sure that all the conection are good, and go from there.
Thanks again for all the info
Old Aug 29, 2010 | 10:24 AM
fordpride's Avatar
fordpride
The GPR is going to click loud
check all batt. cables and get batts. load tested sounds like starter or batts.
Old Aug 29, 2010 | 12:23 PM
Tim Young's Avatar
Tim Young
Hey tim
Before I changed the starter I did change the glow plugs as there were only a few of them working. I also changed the GPR to a larger unit at the same time just for good measure. After all that I was still experiencing the slow to start syndrome to me it seemed as though it turning over OK but I had to crank it over a few times before it would fire. After I changed the starter I found out that it was turning over slower then it should have..
Anyway good luck, I did as most people have recommended cleaned the battery terminals, load tested the battery and tested the cables before changing the starter.
Tim
Old Aug 31, 2010 | 10:14 AM
superduty4x4's Avatar
superduty4x4
If you need a hand let me know, I'm not too far away.
Old Sep 1, 2010 | 10:08 AM
GT_350's Avatar
GT_350
Well I had my batt's tested and the passenger side was low, but then found that one of the conn. on the starter solenoid was loose.
Went to take it off and clean, and of course it broke off lol.
Replaced that but the starter is pulling 900A, so I now know that it's going out.
Appreciate all the help everyone has giving.
Old Sep 1, 2010 | 06:57 PM
fordpride's Avatar
fordpride
This is the starter i put on in DEC. it's for a super duty it's two bolts and spin's it's @$$ off Ultima 03-3716 - Starter 2002 Ford F-250 Super Duty | O'Reilly Auto Parts
ten.mile
May 16, 2020 04:34 PM
06FUN
Oct 29, 2016 07:53 AM
07EXPYEL
Jun 7, 2016 11:51 AM
Grinder Man
Oct 10, 2014 09:35 AM
ten.mile
Dec 11, 2012 05:56 PM
