Sponsored by: Innova
rear camera, reverse signal input?
Old Aug 27, 2010 | 11:56 AM
XHunter's Avatar
XHunter
Hey everyone, for the rear camera installation wiring harness for my nav (pio avic d1), what is the prefered signal wire to connect for the reverse signal input wire?
I have all the ford wiring diagrams, connector views and pin locations, etc.
Should I use one of the following or something different:
reversing lamps relay, control
reversing lamps relay, switched output
thanks in advance!
Old Aug 29, 2010 | 11:58 AM
Shepherd2's Avatar
Shepherd2
As long as it recieves power only when in reverse, just go with whatever is easiest. I think it's a BK/PK wire just below the master cyl.
Old Sep 1, 2010 | 11:29 AM
XHunter's Avatar
XHunter
I found in the diagram on the central junction box (fuse panel) a wire that is labeled "voltage supplied in reverse" and happens to be the BK/PK. thanks for reply.
kingster01
Jan 25, 2015 07:57 AM
rocknrod
1997 - 2003 F150
Apr 24, 2014 10:10 PM
Scottay
Oct 20, 2013 04:38 PM
dzaharias7681
2004 - 2008 F150
Apr 17, 2011 08:19 PM
skoveng
Electrical Systems/Wiring
Feb 24, 2009 07:07 PM
