Reverse Signal Wire in Cab
I'm putting a reverse interior mirror monitor in my 01 Supercrew.
I want to run the camera wires all the way up to the cab and land a reverse signal there.
Anyone know of one there?
Do not want to use the local taillight wires in the rear of the truck.
Power for the backup lights comes through the transmission TRS which completes the circuit when the shift lever is put into reverse.
You will need to take a signal off the lead going back to the backup lights just after it leaves the TRS as the closest you can get to the cab.
Either use a small slave relay and use it's switched contacts with separate fused power or run the live lead fused at the source, into the cab.
Another source of backup signal would be right after the half relay 203 in the engine bay fuse box. This relay connects power through to the 7 pin trailer tow outlet, if you have it.
If you pick that lead out of the bundle, put a splice in the lead and run it to an inline fuse, then through the fire wall into the cab you got it and it would be a short one. Make sure the half relay and it's fuse is in place to do the reversed switching power.
Good luck.
That should work, thanks.
Also isnt there a trailer harness connector to the right of the steering column next to the diagnostic connector? Would that have a backup wire in it?
Thanks again.
Thank you Bluegrass, as usual . . .
