Sponsored by: Real Truck
x codes or add aleaf
Old Aug 27, 2010 | 09:19 AM
fordboy2's Avatar
fordboy2
I am putting a fabtech 3.5 inch shackle lift in my truck here pretty quick, and am thinking of beefing the front springs up to handle my plow better. which do yo all think will be better and why? A set of add aleafs in the front or buying the x codes. If the x codes does anyone have a part number for them. I have had add aleafs in my 01 and was fine with the ride so I am not worried about that. thanks for your input in advance
Old Aug 27, 2010 | 09:29 AM
rwilimo's Avatar
rwilimo
Since your already doing the lift you will have plenty of height, I would go with x code springs as they will droop less with load of the plow. I have x codes with an 8.5' western pro plus and they hold it fine.
Old Aug 27, 2010 | 11:47 AM
fordboy2's Avatar
fordboy2
where did you buy your x codes?
Old Aug 27, 2010 | 11:57 AM
ExplorHer1369's Avatar
ExplorHer1369
I got my set from a local Ford dealer around a month ago.
Part number 2C3Z-5310-AF
U-Bolts are F81Z-5705-ZA
Nuts are N805480-S426
Old Aug 27, 2010 | 01:20 PM
fordboy2's Avatar
fordboy2
wow 166 per spring it would be a whole lot cheaper to do the skyjacker add aleaf I had in my 01.
Old Aug 27, 2010 | 01:21 PM
fordboy2's Avatar
fordboy2
you dont have the part numbers for the f350 blocks and ubolts by chance also do you?
Old Aug 27, 2010 | 02:16 PM
ExplorHer1369
Check to see if you need tapered blocks or not. Mine is an Ext. Cab Short Bed, so my blocks are tapered.
Left Tapered Block: F81Z-5598-FA
Right Tapered Block: F81Z-5598-GA
U-Bolts: 5C3Z5705AA
Nuts: N620485S441
Old Aug 27, 2010 | 02:19 PM
SuperDutyScaler's Avatar
SuperDutyScaler
i dont have a diesel or plow but i hate my add a leaf in the front. ever since i installed it it slaps the factory leaf when you hit bumps or go over speed bumps and trust me i drive her like a grandma. im trying to save up for x-codes but since getting my 78 on the road its been kinda hard with buying lift kit parts for it
380tom
Nov 7, 2013 11:55 PM
SuperDutyScaler
Nov 26, 2010 12:41 PM
SuperDutyScaler
Mar 21, 2010 12:38 PM
BigBlueIron
Feb 18, 2008 09:35 PM
Fordbronco95
1978 - 1996 Big Bronco
Jul 4, 2005 07:07 PM
