Sponsored by: Auxito
using oil
Old Aug 27, 2010 | 04:09 AM
ambyrell1's Avatar
ambyrell1
using oil
i have a 2003 F-150 4.6 4x4, that has started using about a quart of oil a week, i can't find any leaks, there is no smoke, where could the oil be going? The truck has a 101,000 miles on it.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Aug 27, 2010 | 09:24 AM
george6488's Avatar
george6488
you might want to try another forum
Old Aug 27, 2010 | 02:31 PM
LxMan1's Avatar
LxMan1
Moved to correct forum.
Welcome aboard!!
Either valve guide seals or a bad PCV valve.
Old Aug 27, 2010 | 05:52 PM
steve(ill)'s Avatar
steve(ill)
yes, replace the PCV valve and test again.
Old Aug 27, 2010 | 06:18 PM
galaxie641's Avatar
galaxie641
A qt. a week tells us nothing how many miles does it take to eat a qt?
Old Aug 30, 2010 | 12:25 AM
FordMan10's Avatar
FordMan10
My truck does the same thing uses 2 quarts every couple weeks 1997 ford f-150 4x4 with 155k and I was wondering the same thing until one day when I stepped on the gas a little fast I noticed in my mirror and puff of white smoke was not to noticeable,but I still seen it.I have not checked the PCV valve yet.
Where is the PCV valve Located?
Old Aug 30, 2010 | 10:47 AM
1975IH200's Avatar
1975IH200
On the 4.6 engine, the PCV valve is on the right side valve cover, the hose goes around the back of the engine to the upper part of the intake manifold.
Actually there is only hose at each end, with a metal tube in between them. The rubber hose ends deteriorate over the years and may need replaced. The PCV valve can be flushed out with some carb cleaner.
cdat81986
18
Sep 14, 2022 08:02 AM
kailor
43
Jan 20, 2017 03:58 PM
likeshills08
May 1, 2011 05:43 PM
WheelinDixie
Mar 30, 2011 02:37 PM
JamesHajek
41
Apr 12, 2010 02:57 PM
