Hard Cold Start. Help!
Old Aug 26, 2010 | 05:04 PM
dmanser's Avatar
dmanser
Hi Gentlemen,
I've read all your posts & found all very helpful, however I'm sill at odds here and could use a little more insight please.
My truck is an 04 - F250 6.0L 1 year ago I was having this same problem and after a month in a shop they agreed with me tat the Hi Pressure pump was bad and replaced it along with testing, cleaning and resealing injectors. (4K later it was working great) Now 2 weeks ago it starts up again, I am in SoCal so we don't get the low temp like some of you. Morning starts around 50dg outside, fires & dies, fires & dies, maybe 3 - 4 times then starts and runs like it is miss firing for about 2 min then smoothes out, but has no power until it gets to normal temp then is fine and will fire right up until it cools down again.
All oil and filters have been changed at ever 4K and just for the hell of it I changed them all again when this problem started up approx 1400 miles between changes.
I've checked the 7 post FICM yesterday after sitting overnight, with the outside temp around 65dg.
Key on 48V
Buzz test: 13V until glow plug light goes off then 48V
Cranking test 48V
NOTE: Check engine light has never come on.
After the test I took it to a friend with a scanner. The following codes came up: PO264 Injector circuit low cylinder 2 / Harness short to ground.
The same for cylinder 3, 4, 5, 6, 7, & 8. Only cylinder 1 did not code.
I cleared the codes and drove it home approx 12 miles. This morning it fired & died, (60 dg outside)cycled the key & waited 10 seconds tried again and it started but very rough for 2 min then smoothed out with no power until she warmed up. No smoke until the turbo kicks in then a blast of white with a lot of power. I am going to scan it again this morning to see if they come back.
Any Ideas????
Thanks for any info
Dan
Old Aug 26, 2010 | 05:22 PM
npccpartsman's Avatar
npccpartsman
Sounds like FICM since it's dropping to 13V. It shouldn't ever drop below 45 or 46 volts.
Just for giggles and grins have BOTH your batteries and charging system load tested before dropping the coin on a FICM and try the FICM repair procedure if you're game. Check the 6.0 tech folder for FICM repair instructions.
Old Aug 26, 2010 | 05:53 PM
dmanser's Avatar
dmanser
The first thing I did was check voltage, load tested both batteries and checked both alternator outputs. Everything was fine. I just replaced batteries & alternators last year.
The Short to ground in harness is what's getting me.
Old Aug 26, 2010 | 06:00 PM
cheezit's Avatar
cheezit
IMO ckt low codes for all 8 injectors is a ficm concern. well that and you are seeing 13v.
Old Aug 26, 2010 | 06:03 PM
69cj's Avatar
69cj
Short, sweet and factual. I'm not a tech but agree 100%.
Old Aug 26, 2010 | 06:54 PM
dmanser's Avatar
dmanser
I was thinking that also due to the 13V, but what confuses me is the harness short to ground. Can the FICM cause this? I'm just trying to wrap my head around this..
FYI, I just got back from scanning it again, after clearing everything last night it all back again same codes. Do you think the RE-Solder will work here?
Old Aug 26, 2010 | 08:46 PM
cheezit's Avatar
cheezit
I think it may be worth a try. its broke now so whats the worst that will happen. it would still be broken when you are finished right?
utjer
May 28, 2013 05:58 PM
stokes86
Aug 15, 2012 11:48 PM
Diesel32
Apr 7, 2011 07:09 PM
ronnshf
Modular V8 (4.6L, 5.4L)
Oct 29, 2009 05:57 PM
