Dim Dash panel Lights
Old Feb 20, 2002 | 04:48 AM
CollinsCD's Avatar
CollinsCD
I have a 1979 Ford Pick-up that has very dim instrument panel lights. I replaced the headlight switch and made sure all bulbs were working behind the dash and this did not help. Has anyone else had a problem with very dim dash lights?
Thanks!
Craig
Old Feb 20, 2002 | 06:02 AM
jowilker's Avatar
jowilker
Craig, They dim with age. Try carefully removing one of them and replacing it with a new bulb, to see if it burns brighter.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Feb 20, 2002 | 07:07 AM
karljay's Avatar
karljay
And while your at it, get the new halogen bulbs. I got them for mine and they work great. Cost about 3x as much but they really work. I'd also clean the contacts up with a wire brush too.
You should be able to pull the main connector from the back and clean it as well. Some contact cleaner from radio shack should work.
Old Feb 20, 2002 | 08:17 AM
KJKozak2's Avatar
KJKozak2
Yes, I have that problem too in my 78 F150. I can barely tell if the dash lights are on. I just figured I was used to my new truck and it's bright dash, and these just "seemed" dim. Great tips though! Never knew you could get Hallogen dash lights. I know where I'm going for lunch...
Kevin K.
Old Feb 20, 2002 | 08:36 AM
73Custom's Avatar
73Custom
[font color=red size=3]This was discussed recently, check it out - yours is probably the same problem.
https://www.ford-trucks.com/dcforum/61_79/8797.html
Marty
Old Feb 20, 2002 | 11:34 AM
breathinhappily's Avatar
breathinhappily
I would avoid the halogen lights in the dash... I tried them and after about 5 months my dash lights started to act up... When i checked the halogens had started to melt the little plastic light holders...causing it to lose contact with the . I liked the bright light but not the melting...halogens get very hot... Best bet is just to remove the blue caps over the lights and put in new normal bulbs...
Old Feb 20, 2002 | 12:24 PM
dbarracuda's Avatar
dbarracuda
Iowa Ford
Escape & Escape Hybrid
Jun 15, 2014 09:57 PM
82fordowner
13
Apr 8, 2013 04:02 PM
Downriver Thunder
Nov 19, 2009 09:23 AM
DBAPilotDad
17
Sep 1, 2008 01:08 AM
Finnford
May 21, 2003 02:46 PM
