Every time I fuel up my truck it starts to continuiously spill out of the little air/ overfill valve. I try to go slow, pull the nozzel out a bit but still keeps spilling and drips all over the ground and my gas line. Anyone ever have this problem? You can tell by the picture where it leaks and has left a mark behind. Solutions?
you think this could be covered by the 100k warranty? i just dont have the time to take it apart and its going to the dealership to get work done for other stuff.
okay i will try that for sure before i fuel up today. so take that hose off the fuel tank and then shoot a flash light down the filling side and look for blockage.
thanks
Carbon cannisters...I know on gassers if they get clogged you can have a slow fill. They are located behind the rear axle up on the frame. You have to see if the vent hose is clogged.
But don't think this applies to diesels. Just thinking...
I think I may have found the problem. The three screws that hole the gas line in place were adjust to the lowest level for the valve to be hanging on a horizontal like angle, I just unscrewed the three screws and adjusted the gas line so the valve sits on a higher angle almost vertical. Hopefully this fixes the problem. Thanks for your input senix
