6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Fueling Problem
Old Aug 25, 2010 | 07:12 PM
pog23's Avatar
pog23
Thumbs down Fueling Problem
Every time I fuel up my truck it starts to continuiously spill out of the little air/ overfill valve. I try to go slow, pull the nozzel out a bit but still keeps spilling and drips all over the ground and my gas line. Anyone ever have this problem? You can tell by the picture where it leaks and has left a mark behind. Solutions?
Old Aug 25, 2010 | 07:16 PM
senix's Avatar
senix
Are you filling with the big noozle reserved for truckers?
Old Aug 25, 2010 | 07:26 PM
pog23's Avatar
pog23
nope. fueling up at a regular diesel pump. regular sized diesel nozzel sir
Old Aug 26, 2010 | 07:44 AM
senix's Avatar
senix
Then next steps would be to take it apart and figure out where it is plugged.
plugged somewhere that it does not allow for a free flow.
Old Aug 26, 2010 | 08:07 AM
pog23's Avatar
pog23
you think this could be covered by the 100k warranty? i just dont have the time to take it apart and its going to the dealership to get work done for other stuff.
Old Aug 26, 2010 | 08:39 AM
senix's Avatar
senix
No. only 36K bumper to bumper would cover it.
You should be able to take that hose loose at the opening to the tank real quick and just take a flashlight at the other end for a look down it.
that should only take a couple of minutes I would think.
Old Aug 26, 2010 | 08:55 AM
pog23's Avatar
pog23
okay i will try that for sure before i fuel up today. so take that hose off the fuel tank and then shoot a flash light down the filling side and look for blockage.
thanks
Old Aug 26, 2010 | 08:57 AM
senix's Avatar
senix
You maybe able to shine that light right at the point where the hose goes in the tank as well.
that is about the only thing I can think of short of dropping the tank.
Old Aug 26, 2010 | 10:28 AM
pog23's Avatar
pog23
please dont mention dropping the tank lol. i am no mechanic and i really wouldnt want do that. i rather fill it more slow to prevent drips if i can.
Old Aug 26, 2010 | 08:16 PM
senix's Avatar
senix
Carbon cannisters...I know on gassers if they get clogged you can have a slow fill. They are located behind the rear axle up on the frame. You have to see if the vent hose is clogged.
But don't think this applies to diesels. Just thinking...
Old Aug 27, 2010 | 08:34 AM
pog23's Avatar
pog23
I think I may have found the problem. The three screws that hole the gas line in place were adjust to the lowest level for the valve to be hanging on a horizontal like angle, I just unscrewed the three screws and adjusted the gas line so the valve sits on a higher angle almost vertical. Hopefully this fixes the problem. Thanks for your input senix
Old Aug 27, 2010 | 08:42 AM
senix's Avatar
senix
Great! Guess you will know when you fillup.
Old Aug 27, 2010 | 10:06 AM
pog23's Avatar
pog23
i know. i cant afford to be spilling diesel every time i fuel up lol. its going for about $1.059/liter. works out to like 4 bucks a gallon.
