Only gears for the SRW PSDs are the 3.73s. If he doens't believe you, tell him to crawl under the truck and look at the tag on the rear diff cover. Or, look at the axle code on the door jamg and coompare it to the chart in the SD FAQ section of the SD forum.
and here is a post that has a pic of a diff tag that has 3.73 limited slip in the 10.5" Sterling axle that is on the SRW SDsClick Here to be taken to that post.
