H2O Gauge
Old Aug 24, 2010 | 11:45 PM
sano64's Avatar
sano64
H2O Gauge
Can you hook up an aftermarket electrical H2O gauge to the stock wires going to the stock temp gauge?Thanks.
Old Aug 25, 2010 | 02:51 PM
airharley's Avatar
airharley
Should be able too. Check the resistance values of the original sender verse what the aftermarket gauge requires. Sometimes you can use original wiring and that is it IF you don't use the power wire from the cluster harness as it has lower voltage.
Old Aug 25, 2010 | 05:54 PM
sano64's Avatar
sano64
Thanks Mark.It would make for a pretty simple install if they are the same resistance.I appreciate the help.I've got a manual coming for the truck so I can try to answer these things myself.
Scott
Boodrow379
Aug 7, 2013 10:32 PM
h2guy
Jan 14, 2012 02:01 PM
73FOMO
Oct 4, 2011 09:56 AM
GeneStoner
Apr 18, 2003 12:48 AM
Franklin2
Mar 6, 2002 07:49 PM
