Weird door lock problem.
Old Aug 24, 2010 | 10:22 PM
TYZ78F150's Avatar
TYZ78F150
Ok,
I got a 2004 X.
Doesn't matter if it's running, shut off, key in or out of ignition.
The problem is the locks will kind of function by themselves, well sort of. They will keep unlocking, and nothing happens when I push the lock button. I can use the key fob, and they work flawlessly when this happens. Anybody have any ideas?
Old Aug 24, 2010 | 10:26 PM
EXv10's Avatar
EXv10
Sounds like a short or a malfunct in the switch you are hitting on the driver door.
Old Aug 25, 2010 | 11:00 AM
TYZ78F150's Avatar
TYZ78F150
I can hit the pass. switch and same thing. I thought I read somewhere that these switches are wired together?
Old Aug 26, 2010 | 02:18 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
I say driver door switch is the likely cause, I have replaced one before due to a switch having intermittent operation. I don't recall if both switches had the problem since I replaced the driver side the same day as I bought the truck and never sat in the passenger side.
Old Aug 26, 2010 | 12:09 PM
TYZ78F150's Avatar
TYZ78F150
Well the thing is, I popped the panel off and pulled the connector off the drivers switch, and used a piece of wire to simulate the switch, and still it wouldn't lock,just unlock would work. Maybe I wasn't jumping it out right, but what else controls the wiring going to the switch?
SteevenH
1997 - 2003 F150
Nov 17, 2009 02:31 PM
jjs2032
Apr 22, 2008 08:27 AM
Boykinfan
Jun 6, 2006 10:18 AM
mgissen
Aug 11, 2004 09:58 PM
justwufn
Jul 29, 2002 06:05 PM
