Small quirk.
Old Aug 24, 2010 | 07:47 PM
REDFORDFX4's Avatar
REDFORDFX4
Small quirk.
Anyone else notice the foam between the dash and windshield acting like it iis a live and moving up. Only on the corner of the driver side?
Old Aug 24, 2010 | 09:13 PM
awq134's Avatar
awq134
funny you should post this... i just noticed mine the other day. went to tuck in back in and the adhesive was very well stuck to the dash. Fingerprints all over the window and 5 minutes later i had it back where it belongs.
Old Aug 24, 2010 | 09:15 PM
awq134's Avatar
awq134
i have another small quirk now that you mention it. the headliner just above the rear view mirror has what looks to be a rounded notch for wiring to pass through and the headliner cover material is starting to come unglued slightly and bugs the crap out of me... hope you dont' notice the same thing now!
Old Aug 26, 2010 | 11:35 PM
gtrippleb's Avatar
gtrippleb
I was looking at that notch the other day wondering what it was for. Now I'm thinking of adding a overhead console if that's possible in my 2010 stx scab.
Old Aug 26, 2010 | 11:55 PM
tonymansfield's Avatar
tonymansfield
Mine is like that also. A little frustrating.
Old Aug 27, 2010 | 07:56 AM
gtrippleb's Avatar
gtrippleb
I haven't noticed mine coming unglued yet, but then I haven't looked at it that close
Old Aug 29, 2010 | 08:15 AM
bamacommander's Avatar
bamacommander
Mine is coming up on the driver and passenger side.
Old Aug 29, 2010 | 09:49 AM
murph1's Avatar
murph1
mine was sticking up a little when i picked the truck up new...
then a 108 degree day in virginia made it come out quite a bit...
started to mess with it and made a mess,stuck to itself and the dash...
trimmed that piece off
Old Aug 29, 2010 | 11:11 AM
pilot10's Avatar
pilot10
That happened on my MKX. At first I wasn't sure it was moving up- thought I just hadn't noticed it. After a few months it was obviously sticking. Tried pushing it down- too sticky.
Took it to the dealer when the whole strip was sticking up. Service manager said they had to remove the windshield, which would probably break. I asked them to research some alternate solution. They ended up pushing it back down. Made kind of mess that was mostly cleaned up. First time I turned the fan on high I got a face full debris.
A few months later pieces of the gasket started surfacing!!! When they pushed it back down they broke it into pieces- lots & lots of little pieces.
At that point they ended up pulling the windshield- which of course broke. The replacement gasket has not reappeared- it's been 15k miles. Replacement of the windshield caused a little collateral damage- somewhat disappointing but not as bad as I expected seeing all the interior pieces that had to be touched/removed in the process. The replacement windshield has a number of flaws that don't impact vision but are noticeable.
Another thing the service manager mentioned was that on the focus/fusions they would often just yank the strip out and not replace it. In hindsight I would have chosen that option and seen if there was any difference in the interior quietness or any increase in window fogging( the dealer couldn't (or wouldn't) say for sure what the function of the strip was- they supposed it was for vibration or sound damping. I experienced an increase in fogging in that area-possibly the result of the windshield getting sticky stuff on it that was extremely hard to clean.
Hope this helps.
Tim
Old Aug 29, 2010 | 11:48 AM
REDFORDFX4's Avatar
REDFORDFX4
Was at dealer yesterday for oil change and they said Ford will fix it but have to take out windsheild or can just pull it all out, says serves no purpose, had them just cut off exposed part for now.
Old Aug 31, 2010 | 11:42 AM
sbrider's Avatar
sbrider
I was wondering about that foam strip too. Now I have to go look at the passenger side to see if the foam strip is loose there also. I ordered the truck and took delivery in Janurary. It sits in the driveway facing south. Steady sun on the front end all day, every day. Only 4400 miles so far. This time of year, the motorcycle sees more road time than the P/U.
Old Sep 1, 2010 | 09:10 AM
SliderF150's Avatar
SliderF150
interesting....mine popped up as well on the drivers side...was in for an oil change yesterday and they said deal with it next time I need any warranty work done.I pushed it back myself but it slipped upside down and was sticky as other's mentioned.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
