Water passengers side??? Need help
Old Aug 24, 2010 | 07:06 PM
Speedjester's Avatar
Speedjester
Well opened up the glovebox on my 05 F350 PSD the other day and it had water inside it and on carpet.. Not much maybe 1/4 inch or less.. I don't believe its rain because it hasnt rained here for a while...(Yesterday and today it poured and no water in glove box) I have been using the ac alot though....Could the drain be plugged??? If it plugged can it fill and spill into glove box??? And were can I find the ac drain to clean??
Thank you
Old Aug 24, 2010 | 08:26 PM
Maxium4x4's Avatar
Maxium4x4
This single post may work for you, the drain is hard to see from the evaporator core housing.
Ford Truck Enthusiasts Forums - View Single Post - AC Drain
Old Aug 24, 2010 | 08:28 PM
Speedjester
same drain for 99 vs 05??? And do you think it would get into glove box??
Old Aug 24, 2010 | 08:32 PM
sammy77's Avatar
sammy77
Yes it should be. Does it drain from the outside?
Old Aug 24, 2010 | 08:36 PM
Speedjester
Sammy I don't understand what you mean "does it drain from the outside"...
Old Aug 24, 2010 | 08:44 PM
Maxium4x4's Avatar
Maxium4x4
Water will pour out the passengers side onto the floor when the air is on, mine runs like a water hose. Just did my Jeep and it sounded like I was visiting the ocean going around corners....I had water everywhere.
Old Aug 24, 2010 | 08:46 PM
Speedjester
Still cant understand how it could get into glove box???
Old Aug 24, 2010 | 08:51 PM
Maxium4x4's Avatar
Maxium4x4
If you verify the drain tube is clear and working, the only other option would be the windshield.
Old Aug 24, 2010 | 08:54 PM
Speedjester
I always run my AC.. And I just noticed that the other day when I went to install the Block heater core it was dry under there... And it should have been wet because I was running the ac less than 5 minutes before I got under it....
Lets say it is blocked... can it overflow into glove box???
Old Aug 24, 2010 | 08:57 PM
sammy77's Avatar
sammy77
Turn a/c on max and high fan speed. Water should drip on passenger side from firewall where the drain is. If you have water dripping you're drains probably ok. Look for another source to leak(windshield as stated)
Old Aug 24, 2010 | 09:00 PM
sammy77's Avatar
sammy77
Yes it could be possible. You could remove the blower motor and check for signs of water.
