installing a battery isolator
Old Aug 24, 2010 | 06:49 PM
gvmiller's Avatar
gvmiller
want to install a battery isolator 200amp in a 2010 F250. NOCO 200amp isolator.Just a single wire from alternator to alternator post on isolator?
Old Aug 25, 2010 | 07:17 PM
tvsjr's Avatar
tvsjr
The isolator should have three studs on in - batt 1, batt 2, and alternator. Depending on the design, it may also have some control wiring.
The downside is that a true isolator is diode-based... so you take a ~0.7V hit constantly, and bad things happen when you fry a diode. I'm running Kussmaul Auto Isolators in two F150s (09 and 10) which use a control module and continuous-duty solenoid, to provide isolation for the on-board equipment. They work great and are less than $200 delivered. No voltage drop, either.
Old Aug 25, 2010 | 07:44 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Here is a diagram I saved from somewhere, may be of some help. I have Ford's diagram somewhere, I'll post it when I find it.
Justin73supercamper
Mar 25, 2017 09:24 PM
carl2591
Feb 22, 2016 06:44 PM
Reef Tech
Electrical Systems/Wiring
Oct 7, 2014 08:57 PM
johnsjsj
Oct 17, 2010 10:58 AM
seamonkey49
Escape & Escape Hybrid
Mar 1, 2006 08:41 AM
