a/c problems
Old Aug 24, 2010 | 01:04 PM
ricg's Avatar
ricg
a/c problems
i hav a 2004 f250 cc fx4 and im having problems with the a/c not cooling and the recycling air not working... when i put it on MAX a/c the blower slows down vs speeds up....it cools something but other times it hot....and when i put it on recycle i still have smells from the outside coming in as if it were just on a/c.....
Any advise...
Thanks,
Rick
Old Aug 24, 2010 | 10:38 PM
Maxium4x4's Avatar
Maxium4x4
Do you have manual controls or EATC?
Old Aug 25, 2010 | 05:58 AM
ricg's Avatar
ricg
Manual I have the choice of max or just ac
Old Aug 25, 2010 | 07:17 AM
Maxium4x4's Avatar
Maxium4x4
Do you have vaccume? Can you flip to defrost then back to floor? Do you hear the blend door working or clunk?
Old Aug 25, 2010 | 08:16 AM
ricg's Avatar
ricg
It does switch between defrost and ac but I don't hear any clunk
Old Aug 25, 2010 | 08:56 AM
Maxium4x4's Avatar
Maxium4x4
You need to investigate the blend door behind your glove box and see what it is up to.
Old Aug 25, 2010 | 10:24 AM
ricg's Avatar
ricg
O and also wheni put it on max it doesn't blow out as hard as just ac
Old Aug 25, 2010 | 10:48 AM
Maxium4x4's Avatar
Maxium4x4
I'm no expert on this system so maybe Cheezit or Mike will chime in.
The blower does not speed up when you (Max AC) recirculate. The blower motor will be in high position, outside air will be at full vaccume only allowing recirculated air through the system.
The heater control valve (if equipped) is at full vacuum, preventing the flow of hot coolant to the heater core.
The panel/defrost door vacuum control motor is at full vacuum and the panel/floor door vacuum control motor is at no vacuum position, directing airflow to the instrument panel A/C registers.
Old Aug 25, 2010 | 01:27 PM
ricg's Avatar
ricg
Lol I'm a dumb a$$... I looked under the pass side dash and found a walmart bag in the way of the flapper... So that problem is solved... Now the cooling of the ac... When I baby it it seems to get cooler but if I get on it it doesn't get cold... Andy ideas... And thanks a bunch Maxium
Old Aug 25, 2010 | 03:29 PM
Maxium4x4's Avatar
Maxium4x4
Well that is a first ..... The AC is controled by the PCM when you go Wide Open Throttle. Is this happening since you removed the Wally World bag?
Old Aug 25, 2010 | 03:43 PM
ricg's Avatar
ricg
Yeah I know right.... No it was doing it before I found the bag
lowrider50
2004 - 2008 F150
Jul 9, 2014 07:47 AM
TommyR
Aug 9, 2011 09:11 PM
fredpet
Escape & Escape Hybrid
Aug 1, 2005 02:57 PM
fredpet
Jul 25, 2004 01:37 PM
