Sponsored by: Real Truck
4x2 front wheel bearing replace?
Old Aug 24, 2010 | 08:58 AM
cobrarep's Avatar
cobrarep
I have a bit of "play" in the front wheels of my 2WD 05 Ex - 61,000 miles. Wondering about replacing the bearings. Hard to do?
Found lots of info about 4x4 front hubs but nothing really on 4x2.
Appreciate any advice!
Old Aug 24, 2010 | 04:49 PM
BareBones's Avatar
BareBones
Ha. I admit I've never done it, but I suspect that the reason there aren't any write-ups is because it is so simple to do!
Old Aug 24, 2010 | 05:20 PM
TexasRebel's Avatar
TexasRebel
pull off wheel
pull off the caliper
pop off the spindle cover
take off the spindle nut
pull off the rotor
pop out old seal
tap old outer races out of rotor
(Jetwash rotor if properly equipped)
tap new outer races into rotor
tap new seal into rotor
Pack new bearings with grease
place new bearings in outer races
Put rotor back on spindle
spin nut to 0 lash (hand tight)
lock nut with cotter pin (or possibly bendover tab on washer...I haven't taken one of these apart yet)
tap spindle cover back on
replace wheel
drive
Old Aug 24, 2010 | 10:20 PM
EXv10's Avatar
EXv10
Make sure it is the wheel bearings first and then try packing them and re-setting the play first.
Old Aug 25, 2010 | 09:04 AM
cobrarep's Avatar
cobrarep
Thanks EXv & Rebel
Certainly sounds easy enough, pretty much what I remember from doing them on my old 78 F100 and what I thought it should be. Kept reading about how entire hubs had to be replaced and needle bearings with flat spots but figured that was more for the 4x4 guys
Had the truck in for something else and the (insert your own word for crook or bandit or extortionist or ??) service writer guy at the shop was telling me it was a $900 - $1,000 job. And that it needed to be done right away. Sounds more like what, $75 - $100 worth of parts and 2 hours to me...
Exv - could certainly try the repack first, what else might give play? I would try jacking the front end up and lifting on the wheel to see what play I find.
I am out of town right now and not able to pop the wheel off for a look. If "pop" describes 8 torqued nuts and a 70lb wheel/tire! Just trying to gather a little info for a future Saturday.
Thanks for your interest!
Old Aug 25, 2010 | 09:38 AM
bubbasz1's Avatar
bubbasz1
I know you will do this but pack and install back bearing before installing seals, and it could be the slop might mean ball joint time, they could cause slop in the assembly.
GregN
Oct 3, 2025 03:53 PM
06FUN
Oct 29, 2016 07:53 AM
Beaglebus
Feb 17, 2015 09:42 AM
awq134
2009 - 2014 F150
Dec 25, 2014 01:50 PM
pcctim
Apr 14, 2009 11:45 AM
