wicked wheel
Old Aug 23, 2010 | 09:23 PM
crazer42's Avatar
crazer42
wicked wheel
i think that the ww will be my next project!, i just have a few questions, are they all created equal? there are so many places that sell them, are any better than others? also i have read a lot of posts and some say to pull the whole turbo, and some say just remove the housing? and do you just use an impact to take the wheel on and off?
thanks
Old Aug 23, 2010 | 09:32 PM
bulla's Avatar
bulla
I tink day ar all da same. These guys will give you the low down on the perks to both options. I pulled mine so I could inspect the exaust side and delete my leaking EBPV and replaced my turbo pedestal o-rings and inspect my up-pipes. Just food for thought.
Old Aug 23, 2010 | 09:36 PM
bulla's Avatar
bulla
I also changed my ic boots. I ordered everythig from clay @ RiffRaff diesel performance. Great prices and awesome customer support.
Old Aug 23, 2010 | 09:37 PM
tigwelder's Avatar
tigwelder
im sure im wrong but i think for the most part they or made by the same co.
i spent the better part of a day changing mine out.
i pulled the bolts and moved the housing aside leaving the waistgate hooked up. dropped the down tube aside, wraped a screwdriver with tape and fouled the exaust turbo wheel. used a socket wrench to remove the inlet wheel.
then installed the ww.
for something i have never seen or worked on it was not to bad a job.
my ribs were sore for days from laying over the radiator all day even with a blanket rolled up over the front end.
all in all it was worth it and would be something i would do if i had another truck.
Old Aug 23, 2010 | 09:45 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Technically "Wicked Wheel" is a copyrighted name so that is why you see them under many different names. They are all just 94.5- Early 99 compressor wheels that come stock in those trucks.
Old Aug 23, 2010 | 10:01 PM
big poppa's Avatar
big poppa
When I did my stock turbo I swapped out the wheels with the turbo on the truck. With compressor bolts removed I did the screwdriver trick then installed, no problem, worked out great but after hearing a member here that I know personally bend his exhaust side fins and really ruined his turbo, I think pulling the turbo is the safest bet, plus you can inspect everything in that general vicinity and pedestal for leaks and correct them if nessesary.
Old Aug 25, 2010 | 09:01 PM
crazer42's Avatar
crazer42
i have also heard people say that you have to have the new wheel balanced? is this true?
Old Aug 25, 2010 | 09:15 PM
Riffraff Diesel
PREMIUM SPONSOR
New wheel comes already balanced. Some suggest balancing the assembly, and if you have access it doesn't hurt. But I have seen turbos that have gone over 60,000 miles after rebuilding and putting on a 'WW' with no issues so I wouldn't worry about it.
xumeng12
Nov 22, 2024 04:39 AM
daves54
Jan 9, 2009 07:12 PM
lawpowerstroke
May 11, 2008 12:42 PM
444dieselrod
21
Sep 16, 2004 08:47 PM
rebellforever
27
Nov 28, 2002 06:14 AM
