Wicked Wheel
Old Sep 12, 2004 | 04:39 PM
444dieselrod's Avatar
444dieselrod
Question Wicked Wheel
I have seen a few peoples signatures say wicked wheel I was just curious as to what it is???
Diesel rod
Old Sep 12, 2004 | 05:02 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's an aftermarket intake wheel for the 99+ guys. It will fit on your 97, but would basically be a stock replacement.
Old Sep 12, 2004 | 05:48 PM
farmb0y's Avatar
farmb0y
Is there any difference in the turbo between an early and late '99?? Some reason I thought I remember reading something about there was, but don't remember.
Old Sep 12, 2004 | 06:10 PM
CAT_man_963's Avatar
CAT_man_963
Yea - I think the early '99s basically have a wicked wheel from the factory - but they changed it to cut down on the turbo noise. '99.5 and on have the different wheel and the Wicked Wheel is an upgrade for them.
Old Sep 12, 2004 | 06:23 PM
farmb0y's Avatar
farmb0y
I can see that being true, compared to a 2002 truck at work, my turbo screams a heck of a lot more than the newer truck. But that reason alone is why I bought my truck, I love the scream of a turbo on a diesel... Ok, it's not the ONLY reason.
Old Sep 12, 2004 | 07:20 PM
Finally's Avatar
Finally
Do you have to pull the turbo to change the intake wheel? I want to change mine since it is kind of chewed up from previous owner abuse. I noticed there are a few bolts that hold the cover on, but didn't know if it would clear the valve cover.
Old Sep 12, 2004 | 08:17 PM
refuse2's Avatar
refuse2
I've heard of some guys doing it with the turbo on the truck I hope this is the method that I plan on doing some time but they recommend to take the turbo off the truck and on the bench.
refuse2
Old Sep 13, 2004 | 09:38 AM
LuLuGoin2ADiesel's Avatar
LuLuGoin2ADiesel
The older turbo's don't have wastegates either
Old Sep 13, 2004 | 12:48 PM
RickyBR's Avatar
RickyBR
where is a good place to get a wicked wheel?
Old Sep 13, 2004 | 04:52 PM
BBBxcursion's Avatar
BBBxcursion
dieselsitetoo.com
Old Sep 13, 2004 | 07:16 PM
refuse2's Avatar
refuse2
http://www.dieselsitetoo.com/index.a...PROD&ProdID=47 this is the link directly to them.
refuse2
Old Sep 13, 2004 | 09:53 PM
444dieselrod
Thanks for the replies guys. now I know.
Diesel rod
Old Sep 13, 2004 | 10:21 PM
WA.Ranger's Avatar
WA.Ranger
I've read that this cuts down on the "flutter" that I just experienced after putting my Tymar on and climbing some of the passes through OR. I want to know if it's worth it? Does it increase the felt HP?
Old Sep 14, 2004 | 09:56 PM
Bob Goodsell's Avatar
Bob Goodsell
Talking
I just had a Wicked Wheel installed on my 99.5 and it does everything the seller said it would do including eliminateing the turbo surge or flutter. I wish I had done this long ago. Sounds nice and does have more low end power .
Bob
Old Sep 14, 2004 | 10:02 PM
refuse2's Avatar
refuse2
Bob
Did you do it or have it done? Just wondering how hard it truely is.
refuse2
