Sponsored by: Real Truck
overdrive question
Old Aug 23, 2010 | 05:55 PM
kx125str99's Avatar
kx125str99
overdrive question
When should overdrive be used? And when should it not be used. I have a 2000 f250 7.3 but have never really used the overdrive.
Old Aug 23, 2010 | 06:08 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It should be used when you're driving. If you need more engine braking coming down a grade turn it off.
Old Aug 23, 2010 | 10:16 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Just don't let the transmission hunt for gears; it doesn't really matter where it settles down, if the TC is locked and it's not pulling hard, go for it.
Did you regear your axles for the (I'm guessing from your avatar) 40" tires? If not, I'd be surprised if you could use OD at all, just because the engine would be revving so low under 65 you wouldn't have the power to move the truck. At 65mph, you'd be turning ~1500rpms in OD, not a lot of oomph to move the truck
Old Aug 23, 2010 | 10:30 PM
Monsta's Avatar
Monsta
Sit. Stay.
That's funny!
Old Aug 29, 2010 | 10:09 PM
kx125str99's Avatar
kx125str99
no its not re geared and it is on 40's. But i tow a 30 foot toy hauler no problem.
