Aux.tank Filler hose replacement - help!
Old Aug 23, 2010 | 08:08 AM
alvald83's Avatar
alvald83
My aux.tank hoses look as though they are ready to crumble, so i guess its time to replace them. And since my sender unit does't work i guess i'll change that as well. I was hoping someone would be able to tell me that i wouldn't have to drop the tank, but i quess thats wishfull thinking. Thanks for your help.
Old Aug 25, 2010 | 03:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by alvald83
My aux. tank hoses look as though they are ready to crumble, so i guess its time to replace them. And since my sender unit does't work i guess i'll change that as well. I was hoping someone would be able to tell me that i wouldn't have to drop the tank, but i quess thats wishfull thinking. Thanks for your help.
What hoses are you refering to? The filler hose and the vent hose?
Does your truck have the optional 25 gallon auxillary fuel tank that fits on the inner side of the drivers side frame rail, has an exposed fuel cap, or is it something else?
The sending unit for the 1967/72 factory auxillary tank is obsolete, no one reproduces it. A few NOS sending units can be found. The float is the usual cause why sending units do not work, because...
The float is made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
The float (COAZ9202B) is still available from Ford and fits ALL 1957/79 Passenger Cars/Trucks/Bronco's & Econolines.
The sending unit's gasket (COAF9276A) is also available from Ford, fits the same applications as above...except senders used with the In-Cab fuel tanks.
Old Aug 25, 2010 | 07:28 AM
alvald83's Avatar
alvald83
NumberDummy,
I am referring to both the filler and vent hose. The tank is the tank between the rails under the bed with the filler hose coming out above the bump, i assume this is the Aux. tank. ( I have a '69 f250). Thanks Al
Old Aug 25, 2010 | 09:27 PM
garbz2's Avatar
garbz2
Bad news is the easiest way to replace the hoses is to remove the bed. They travel over the frame.
The tank sending unit and wiring can be accessed by removal of the skid plate. and worked on from above.
Garbz
Old Aug 26, 2010 | 12:39 AM
NumberDummy
NumberDummy,
Factory installed 25 gallon auxillary tank, has a metal shield inside the bed to protect the filler neck.
1967/69: The filler neck/cap is above the bump. 1970/72: The filler neck/cap is below the bump.
C8TZ9047F .. Filler Hose-includes vent hose which was taped to it / Obsolete
Fits: 1968/69 F100/250 Stylesides.
No Ford Dealer or obsolete parts vendor has any. Not listed in Carpenter's 1967/79 repro parts catalog.
D7TZ9275B (replaced DOTZ9275D & C8TZ9275A) .. Fuel Tank Sending Unit / Obsolete
Fits: 1968/72 F100/350 Styleside w/Auxillary Fuel Tank.
Fits: 1977 F250 4WD Regular/Crew Cab Mid-Ship fuel tank without Evap. Emission-from serial number Y20,001 (not a High Boy).
Fits: 1978 F150/250 4WD Regular Cab Mid-Ship fuel tank with Evap. Emission.
Fits: 1978 F250 4WD Crew Cab Mid-Ship fuel tank with Evap. Emission.
D7TZ9275B =
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
KLIMESH MOTOR SALES in Calmar IA has ONE = 563-562-3241.
DOTZ9275D =
GREEN SALES CO. has SIX.
C8TZ9275A =
GREEN SALES CO. has ONE.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
Carpenter's 1967/79 catalog lists none of these sending unit part numbers.
Verify that the float isn't full of gas before buying one a these sending units. The float comes with the sending unit or is available by itself.
COAZ9202B .. Fuel Sending Unit Float-Available from Ford.
Fits ALL: 1957/79 Passenger Cars/Trucks/Bronco's & Econolines fuel sending units.
MSRP: $13.17 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $9.48.
Old Jan 1, 2011 | 08:10 AM
alvald83's Avatar
alvald83
If i remove the bed access panel, will i be able to access Both hose connections. My bed has been dressed with hurculiner and i dont want to mess it up if i dont have to.
Old Jan 1, 2011 | 09:07 AM
Alex from GA's Avatar
Alex from GA
If I remember correctly when I changed mine I didn't remove the tank. It was many years ago; probably 20. My gage hasn't worked in that long either.
Old Jan 1, 2011 | 11:15 AM
Able Dog's Avatar
Able Dog
I cut my hose in half to get the bed off for its trip to the paint shop. I figured I would just buy a new one.....bad idea. That hose was formed to fit between the bed and frame. I tried fitting a piece of regular fuel hose but it kept collapsing.
That was 11 years ago, if you find a fix please let me know.
Thanks.
90pioneer
22
Sep 15, 2017 09:35 PM
bellssn690
May 27, 2016 06:56 PM
abyars111
15
Sep 28, 2013 04:16 PM
jleal_21
May 25, 2012 11:46 PM
bigred66
Apr 6, 2011 05:40 PM
