EMP proofing
Old Aug 23, 2010 | 06:28 PM
Stewart_H's Avatar
Stewart_H
Toilet paper.
Stock up.
It'll be more precious than gold.
Stewart
Old Aug 23, 2010 | 06:44 PM
F350-6's Avatar
F350-6
As mentioned, having a manual won't help too much. The fuel injectors are fired by the PCM and IDM, so if either one of those go, you'll only be able to move down hill.
As to the other comments, I don't think the intent of carrying the spare parts around is as much to have the only vehicle running as it is to just be able to get home or to where ever your destination is. If you're smart enough to recognize an EMP blast for what it is, and get your truck back up and running, the rest of the folks will still be in shock as to what happened. When you drive by, you'll probably hear everyone try their starter since they see one vehicle working, they'll assume theirs should start up too. Remember no radio and no cell phones means it will take a while for everyone to figure out what's going on.
Old Aug 23, 2010 | 09:28 PM
BLK94F150's Avatar
BLK94F150
If it does go down, stop by. I'm sure my AK-47 will still work and I can make beer. Let's team up.
Mike
Old Jul 13, 2012 | 07:16 PM
wolfpacksix's Avatar
wolfpacksix
Exclamation Answer
I don't know about diesel, but I do know for an 06 FI50 XLT 4x4, this is the (literally) $15.00 answer.
Hi, I am a professional certified mechanic, with an engineering background, and 35+ years experience. I will do my best to assist you. Also keep in mind I don't know if you are a pro or a novice so we may have to fine tune the answer. Feel free to add any additional info you feel is needed as we go on. Always keep in mind that I am here to help you with any questions.
The list would vary with the severity of the EMP. The basic list would be
Electronic voltage regulator in the alternator
An extra set of relays and fuses fror the relay fuse panel.
An instrument cluster, because it contains microprocessor.
ABS control module
PCM Power train control module
A massive EMP can even fry electric motors. But if you have this list of parts shielded, it can get you through just about anything conceivable. A very good plan is to have an older car from the 60's or early 70's as a backup, because they are virtually immune to EMP, except for the voltage regulators that control the alternator. If you have any more questions, as always, I am here to help. Good luck with it, have a great day, and Thanks for using Just Answer.
Old Jul 13, 2012 | 07:17 PM
wolfpacksix
Mike
My AK is in working condition also. Ford Raider Crew.
Old Jul 13, 2012 | 07:27 PM
lartross's Avatar
lartross
Or just get an IDI, manual shift...good to go.
Old Jul 13, 2012 | 09:16 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Oh dear lord..................
Old Sep 28, 2015 | 05:06 PM
FordJunky1289's Avatar
FordJunky1289
ABS control module
I know this is a old tread but I have a 1989 Ford F150 with the inline 6 with 5 speed manual transmission.what would have to be replaced on it in the event of a emp.
Old Sep 28, 2015 | 05:29 PM
Jaime74656's Avatar
Jaime74656
Originally Posted by danskool
I am thinking. If we were to get hit, and you had the only vehicle running. There could be trouble. Might need a good army to keep folks from stealing it from you. Plus you will have to steel fuel to keep it running. Stations will be down. Just a very ugly time that would be for all.. It would make good people turn bad just to survive.
And that's where diesel users would have the advantage over the gassers, why?
Simple...even if the pumps go down we still could run to any place with used or new oil, trans fluid, or similar and buy that and top off, ironically I was thinking about this type of situation at work...
Last edited by Jaime74656; Sep 28, 2015 at 09:14 PM. Reason: fixed due to phone auto correct
Old Sep 28, 2015 | 06:26 PM
F350-6's Avatar
F350-6
Originally Posted by Jaime74656
Simple...even if the pumps go down we still could run to any place with used or new oil, trans fluid, or similar and buy that and top off, ...
If we want to play this scenario, then one should simply have a 12v pump rated for suction to pump fuel. Just because the world has ended and there is no electricity does not mean the gas stations are out of gas, they just can't pump any.
A siphon hose down the little covers in the parking lot used to fill the underground tanks will re-fill your tank if you have a 12v pump to run it.
Just don't confuse the gas and diesel tanks.
Old Sep 28, 2015 | 07:34 PM
Jaime74656's Avatar
Jaime74656
Agreed, but I was thinking more into the scenario with the assumption that other might have already explored that option as well
Old Sep 28, 2015 | 07:52 PM
bigb56's Avatar
bigb56
hmmm guess I keep my old Mercedes 300D.
Old Sep 28, 2015 | 09:18 PM
  #28
Jaime74656's Avatar
Jaime74656
or really any older Diesel engine honestly...thats what I would be going to if I had....oh wait...I already got the great 7.3
Old Sep 28, 2015 | 09:46 PM
  #29
bigb56's Avatar
bigb56
Cept the old 300s got no PC. Old fashioned Bosch Mechanical Ip and accelerator linkage hooked up to the pedal. 25-30 MPG and will burn just about anything you can find to pour in there.
Old Sep 28, 2015 | 09:49 PM
  #30
bigb56's Avatar
bigb56
Just noticed this is a 5 year old thread, and nothing has happened yet. Maybe I'll sell the Benz after all.
