Power steering pump options??
Old Aug 22, 2010 | 05:52 PM
77_150_460's Avatar
77_150_460
I have a 1977 F150 2wd auto w/460.
My truck came with the large round power steering pump with the reservoir "pressed" onto the pump. However, the stock one was leaking between the reservoir and the pump, so I bought a new one... that came with a plastic reservoir. Surprise! This brand new one leaks in the exact same spot - do have I have better options?
Thanks!
Old Sep 2, 2010 | 10:02 PM
77_150_460's Avatar
77_150_460
Nobody else has this issue or has found a better design of pump to swap in? I have a lot of money in the rebuilt engine and transmission that got rid of 999 of my 1,000 previous leaks, this last one is proving difficult...
Old Sep 3, 2010 | 05:47 AM
jim collins's Avatar
jim collins
Your old one just wore out and the seal gave way which happens. The new one may have been assembled wrong when it was rebuilt,in which case, thats where you use your warranty. You may be able to mount a newer pump that uses a remote fill that is seperate from the pump. I'm not sure but somebody will come along with a better idea. Good luck.
Old Sep 3, 2010 | 05:58 AM
DKW 86's Avatar
DKW 86
What he said, just swap out the pump, you just got coincidental leak in my opinion. Put these things together 24/7 and almost never have a leak. We sell a lot of pumps but not reservoirs. We swap them all the time.
Old Sep 3, 2010 | 02:44 PM
Blown 331's Avatar
Blown 331
I just put a new PS pump on my 77 F-150. It has a metal reservoir but it's not pressed in. It has a large nut on back of the pump where the high pressure line bolts on that holds it together.
I paid under $40 for a rebuilt one at O'Reilly. I just put it on last week, no compaints so far. My pump has a metal reservior as well.
Old Sep 3, 2010 | 10:14 PM
4x4 Bart's Avatar
4x4 Bart
The best pump is the Saginaw 20-6244. The pumps with the plastic reservoirs sometimes whine a lot and leak. Bought mine from Advanced Auto. about 50 bucks.
Old Sep 4, 2010 | 12:21 AM
1977f250's Avatar
1977f250
I agree with Bart I am still looking for a 460 van for the brackets for the GM tear drop pump. Only vans I have found in the yard with a 460 the brackets are long gone.
Old Sep 4, 2010 | 06:44 AM
Blown 331's Avatar
Blown 331
I wish I would have researched the saginaw pump before installing a stock replacement last week! Oh well, I the stocker works fine for me. I'm not in tough off road conditions much.
juanbad79
23
Nov 10, 2016 04:47 PM
perryg114
1983 - 2012 Ranger & B-Series
Jan 13, 2016 12:43 PM
Dank Hill
64
Dec 23, 2015 11:20 PM
dbuck50
2004 - 2008 F150
Jul 29, 2015 06:58 PM
sheamus
Oct 29, 2009 08:16 AM
