How far can I advance the timing?
Old 06-24-2010, 05:34 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
I have a Live wire tuner from 5 star on my CVPIs 4.6.
Last night I started playing with the setting and set the timing 2* more than what Mike had it set at. It sounds better and the power is much better from idle up to redline! I would really like to add more into both this tune and the 91 drag strip tune, but don't want to over do it.
So what do I want to watch on a data log to find out how close I am to the limit? I am thinking of taking it to the track in the next couple weeks and want to get it tuned for every little bit of power first, but I don't want to gurt anything.
What will this do to fuel mileage?
Thanks guys.
Old 06-26-2010, 11:47 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
How much total advance are you running now?
Old 06-27-2010, 01:21 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
EXCURSIONATOR1 is offline
Can you monitor knock with live wire?
Old 06-27-2010, 04:21 PM
bill11012's Avatar
bill11012
All the Live wire tells me is 2* more than the tune was set to when it was sent to me. I can Email Mike and find out what he set it to.
Yes, but I have no idea what I'm looking at.
Old 06-27-2010, 07:10 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Using a Snap On timing light you can check the initial timing and then run the engine up to about 3,000 rpm or until there is no more advance coming in and just read the numbers on the light.
Old 06-27-2010, 11:40 PM
EXCURSIONATOR1
Can't do that with newer engine management systems. Timing is based off of load and rpm gear etc.....
Old 06-28-2010, 09:29 AM
bill11012's Avatar
bill11012
Edit
Never mind. I miss under stood your post.
Old 07-10-2010, 11:20 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Watch for knock sensor output if you have it.
Old 08-30-2010, 05:00 PM
bill11012's Avatar
bill11012
I finely got time to get back to this. All I can find is " spark ". Is that it?
ARW
36
10-04-2015 11:44 AM
Crumm
6.2L V8
21
09-03-2015 08:30 PM
Ltngdrvr
6.7L Power Stroke Diesel
09-22-2014 09:03 PM
fordf150guy
12-07-2013 10:59 AM
DIYMechanic
58
11-23-2013 11:28 AM
Quick Reply: How far can I advance the timing?
