Sponsored by: Auxito
Compression issues?
Old Aug 22, 2010 | 12:25 AM
HonkyTonkFronk's Avatar
HonkyTonkFronk
Compression issues?
Hey all, I've got a 1997 F-250 XLT, 4.6L that was a project truck but due to some financial problems has become my primary vehicle. Suddenly the little problems are more important.
After starting the truck, the engine runs as if it's misfiring a cylinder. If I let it idle for about a minute the problem goes away. The number 4 cylinder was recently not firing due to a faulty spark plug wire, but I've fixed this problem.
Any experience with this? I suspect compression issues. It's not throwing codes, so I don't know if this is a big deal or not.
-HonkyFronk
Old Aug 22, 2010 | 08:25 AM
steve(ill)'s Avatar
steve(ill)
i believe my 5.4 has a small pin hole in the head gasket on #1 cylinder. A year ago it did as you said. Every morning it would miss for 1 minute, then o.k. I noted a cup full of antifreeze missing in about 2 weeks. My theory is the small hole did not allow much compression into the antifreeze, but when the truck set overnight it would leak a spoon full of water into the combusion chamber. Every morning i had the missfire for a minute. I did get a code every now and then.... ended up putting a bottle of BARS head gasket and block sealer into the antifreeze and that fixed it... been about a year.
Old Aug 22, 2010 | 08:29 AM
steve(ill)'s Avatar
steve(ill)
Bar's Leaks Liquid Copper Block Sealer
Old Aug 22, 2010 | 09:30 PM
HonkyTonkFronk
I tested compression and found it to be below the other cylinders. The other cylinders have around 120 psi compression while number 4 sits at 85 psi. I'll still give the leak stopper a try and let you know how it goes. Thanks!
-HonkyFronk
Nally427
Aug 28, 2013 04:59 PM
1986 4x4
Feb 14, 2013 07:51 PM
Racerlinn
Apr 19, 2012 08:28 PM
fordflaresides
15
Dec 12, 2005 04:40 PM
p.davis
Mar 17, 2004 06:07 PM
