Headlight Problem WTF
Old Aug 21, 2010 | 11:07 PM
Sycostang67's Avatar
Sycostang67
I would start with the headlight switch, thats been an issue with ford since the 60's. The high/low/wiper/TS switch if needed can be replaced with out removing the steering wheel. I had to do it 3 times in one day.
Old Aug 22, 2010 | 01:17 AM
rupejosh's Avatar
rupejosh
pull the switch out and ill bet you find some wires have been hot and turned brown/black mine didnt get to smelling bad but when i did pull the switch it looked like some little mystical wire wrecking creature had been back there with a lighter
Old Aug 22, 2010 | 10:55 AM
kyle j's Avatar
kyle j
so i should take the dash apart to get to the switch, and then check then one on the steering collume. also i looked at the wires ner the headlights and its a mess of wires under there, how do i tell if there bad or not cant really tell if they are burnt?
Old Aug 22, 2010 | 12:29 PM
Sycostang67
If you remove the front dash panel, you should have fairly easy access to the headlight switch. I would just start with the switch for now as it sounds like it is overheating. Inspect the plug that connects to the headlight switch, the wire for the marker lights likes to melt.
Old Aug 23, 2010 | 02:02 PM
kyle j's Avatar
kyle j
ok so i have to quick questions, How do i take off the **** on the dash for the headlights i cant get the dash pannel off because of that ****. Second the headlight/windshelid lever on the steering wheel dosent need to be looked at untill i look at the one on the dash correct?
Old Aug 23, 2010 | 02:47 PM
LCAM-01XA's Avatar
LCAM-01XA
The **** has a little spring-latch-thing on its back side, can't really see it easy unless you use a dental mirror. To release it you need to press on it with something like a curved pick, and if you look at the **** on its back edge there is a little notch - this is where you push (well, pull towards you) with the curved dental pick, right behind that notch is the spring-latch-thing.
Old Aug 23, 2010 | 10:09 PM
greywynd's Avatar
greywynd
A small screwdriver, using the edge of the blade in the slot will work to release the clip too. I don't even look anymore, I just hold the screwdriver there, and turn the **** til it clicks, and give the screwdriver (and the ****) a light pull.
Old Aug 24, 2010 | 10:58 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
The explained method is for the wiper **** ...
For the headlight switch there is a release button on the switch, reach up under the dash touch the end of the switch and follow the side opposite the connector towards the dash, you will feel a button (about 3/16" in diameter and about 3/8" tall) with a little spring, push that button and it releases the headlight **** and shaft.
-Enjoy
fh : )_~
Old Aug 24, 2010 | 12:59 PM
greywynd's Avatar
greywynd
Oops...missed that it's a '94, everything I think of is '87-91!!
Old Aug 24, 2010 | 05:32 PM
kyle j's Avatar
kyle j
and is there some trick to take off the black dash peice, i Couldent get the left side loose so i tugged and broke **** now i cant get it back on
Old Aug 24, 2010 | 05:45 PM
rodneywar's Avatar
rodneywar
it snaps back on at least thats what mine does
Old Aug 24, 2010 | 09:40 PM
Sycostang67
If you pry out the 2 trim strips on either side, it will reveal a couple screws. After that, you can gently pry the panel off.
Old Aug 25, 2010 | 01:30 AM
  #28
Festus Hagen
Methanoholic
Actually, It's my fopah I believe
The 87 and up the clip is on the **** as first described isn't it ...
I participate in two forums, the IDI forum and 80-86 forum... If it's a truck (not motor) question, I assume I'm in the 80-86 forum!
-Enjoy
fh : )_~
Kilomanjaro
Feb 23, 2022 12:14 PM
Country_boy_2007
Dec 25, 2013 01:46 AM
lovestrucks
Electrical Systems/Wiring
Oct 4, 2013 10:28 AM
loyal
Jun 14, 2009 03:46 AM
SCOOBYMEISTER
1978 - 1996 Big Bronco
16
Aug 2, 2006 07:58 PM
