I would start with the headlight switch, thats been an issue with ford since the 60's. The high/low/wiper/TS switch if needed can be replaced with out removing the steering wheel. I had to do it 3 times in one day.
pull the switch out and ill bet you find some wires have been hot and turned brown/black mine didnt get to smelling bad but when i did pull the switch it looked like some little mystical wire wrecking creature had been back there with a lighter
so i should take the dash apart to get to the switch, and then check then one on the steering collume. also i looked at the wires ner the headlights and its a mess of wires under there, how do i tell if there bad or not cant really tell if they are burnt?
If you remove the front dash panel, you should have fairly easy access to the headlight switch. I would just start with the switch for now as it sounds like it is overheating. Inspect the plug that connects to the headlight switch, the wire for the marker lights likes to melt.
ok so i have to quick questions, How do i take off the **** on the dash for the headlights i cant get the dash pannel off because of that ****. Second the headlight/windshelid lever on the steering wheel dosent need to be looked at untill i look at the one on the dash correct?
The **** has a little spring-latch-thing on its back side, can't really see it easy unless you use a dental mirror. To release it you need to press on it with something like a curved pick, and if you look at the **** on its back edge there is a little notch - this is where you push (well, pull towards you) with the curved dental pick, right behind that notch is the spring-latch-thing.
A small screwdriver, using the edge of the blade in the slot will work to release the clip too. I don't even look anymore, I just hold the screwdriver there, and turn the **** til it clicks, and give the screwdriver (and the ****) a light pull.
For the headlight switch there is a release button on the switch, reach up under the dash touch the end of the switch and follow the side opposite the connector towards the dash, you will feel a button (about 3/16" in diameter and about 3/8" tall) with a little spring, push that button and it releases the headlight **** and shaft.
