Coolant Flush
Old Aug 21, 2010 | 07:51 PM
lewis racing's Avatar
lewis racing
Coolant Flush
In the middle of my first coolant flush and im having a blast. I've drained it twice, and will continue tomorrow. ( I got started kinda late) It feels good to be doing some important maintenance yourself. I want to thanks everyone for the advice and the good posts. I will continue tomorrow till the water runs clear..lol
Old Aug 21, 2010 | 07:55 PM
MNDiesel2's Avatar
MNDiesel2
It does feel good not to go hand in the good hard cash.
Where's the procedure, or advice or where did you get the info. Is it in the tech folder.
Thinking I should do mine, and add the filter. Dealer says flush was completed when the heads were done, but did they flush or just replace the antifreeze.
good luck
Chris
No Siggy Yet not enough posts!!
Old Aug 21, 2010 | 08:09 PM
rocky1074's Avatar
rocky1074
Check out this thread
https://www.ford-trucks.com/forums/8...tructions.html
Old Aug 21, 2010 | 08:16 PM
BLADE35's Avatar
BLADE35
seems like the vc-9 did the most cleaning with the thermistat out and then you can reverse flush with it out as well
Old Aug 21, 2010 | 09:49 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
good luck
Chris
If they removed the heads, they replaced the coolent and prob did a flush too. Look at your invoice, it should say.
