Riffraff FRx Question
Old Aug 21, 2010 | 04:40 PM
kjf-250's Avatar
kjf-250
So I installed the FRx kit from RDP today. I made extra sure that I got the spring and plunger on the FPR straight, but im still paranoid. I read that if it is not in the center it will cause the fuel pressure to be higher than normal. Is there any way to tell if the spring is straight w/o a fuel pressure gauge? I have driven the truck and it runs flawlessly. Would you notice a difference in the way it ran if the fuel pressure was higher?
Thanks,
kjf-250
Old Aug 21, 2010 | 08:11 PM
wolfrace's Avatar
wolfrace
You like apples?
when mine was over 100 psi I could not tell the difference than when I got it down to 62psi........................ the only thing I noticed were some leaks. Get a feul pressure guage, I farted around trying to make one and ended up just buying a generic feul pressure tester and hooked it in to the feul bowl drain..................... showed right away I had over 100psi.
MTRoofer
Mar 5, 2013 10:37 PM
endobear
Apr 28, 2012 09:04 PM
kjf-250
2004 - 2008 F150
May 26, 2010 09:19 PM
kjf-250
May 10, 2010 01:27 AM
kjf-250
2004 - 2008 F150
Apr 11, 2010 06:38 PM
