1986 4.9l timing
Old Feb 16, 2003 | 12:16 PM
dt466s's Avatar
dt466s
Angry 1986 4.9l timing
Can anyone tell me how to set the timing on a 1986 4.9 with a TFI ignition. initial timing is to be at 10 deg. btc but setting it without the engine running it shows that i'm 180 deg. out of time. can my dist possibly be wrong from the factory???
Old Feb 16, 2003 | 01:35 PM
steve83's Avatar
steve83
1986 4.9l timing
No, you just need to turn the crank over once. The camshaft & dist turn at 1/2 the speed of the crank, so you're just on the exhaust stroke instead of compression. Look at the sticker on the core support for the procedure. If it's missing, look here.
kid chuckles
Mar 30, 2012 08:34 PM
David Thomas
Jan 19, 2011 07:26 PM
HOEO
Dec 27, 2006 03:35 PM
blueknight44
18
Feb 25, 2006 08:01 AM
cocot
Jun 30, 2003 12:13 PM
