6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Modifying the DPF and Leaving It Installed
Old Aug 21, 2010 | 09:05 AM
kiggy74's Avatar
kiggy74
All the discussion regarding basic/inexpensive performance mods to the 6.4L PSD seem to be in regards to removing the DPF, replacing it with an aftermarket exhaust and/or straight pipe, and retuning with a tuner module. Apparently this creates a potential for being denied warranty coverage, and putting the DPF back on isn't necessarily practical in all cases (when traveling).
So what if the stock DPF was modified to improve its aspiration? I wonder if anyone has tried opening one up to remove some of the filter mechanism inside. What if you could help it move more air but leave all of the sensors etc in place, and do it in such a way that modification was undetectable without the dealer cutting the thing open. I imagine that you could do it in such a way that regens still occur, but maybe not nearly as frequently, meaning no tuner module is necessary for those not willing to take the risk.
If this could be done, I could see a real market for a company like Bully Dog or Banks to offer the modified DPFs with a core return of your original DPF. Does such a thing exist?
Old Aug 21, 2010 | 09:18 AM
sdetweil's Avatar
sdetweil
someone here or in the Superduty section was talking about a hollowed out core, passthru for his truck..for visual inspection
Sam
Old Aug 21, 2010 | 09:23 AM
kiggy74's Avatar
kiggy74
I don't know if you could leave it hollow, I doubt it would sound the same unless a straight tube was added down the middle. I don't know what the inside looks like but I'm assuming it has some baffles and a matrix of metal screens (total guess). I'd be real interested to see what would happen if you removed enough of the internals to allow more air to pass through while still retaining its original function.
Old Aug 21, 2010 | 09:40 AM
sd convert's Avatar
sd convert
Interesting comment. I'm sure that you just got the juices flowing.
Old Aug 21, 2010 | 04:59 PM
LaxPlaya21's Avatar
LaxPlaya21
My main concern would be when the truck goes into regen and it begins dumping fuel and sending the EGTs through the roof. I am pretty confident the truck would throw a code. And if the main goal is fuel savings, not addressing the regen cycle will not increase MPG that is for sure. So to me, a straight pipe and a tune seems to make the most sense... You are addressing both the pipe and the regen.
Old Aug 21, 2010 | 08:39 PM
sdetweil's Avatar
sdetweil
well you couldn't allow regen of course.. have to have a tuner, but you don't need to leave the tuner installed when u take it in for inspection etc..
this was only for visual inspection purposes.. without pulling the case off, no one (normal) would ever know
Sam
Old Aug 21, 2010 | 08:40 PM
StanleyZ's Avatar
StanleyZ
Good thinking, but with a few questions. Wouldn't that hollow exhaust with a regen make the truck into a flame thrower, I think there was a utube video about it. Good idea putting a pipe inside a hollow DPF to pass visual inspection except the black exhaust would at least raise questions for an inspector who knew what they were looking for. And, there is still the warranty issue, I don't think the hollow DPF would fool a ford tech.
Old Aug 21, 2010 | 08:43 PM
sdetweil's Avatar
sdetweil
well, they say (other section), that you have to put your foot in it to get soot exhaust...
isn't a DPF delete a straight thru pipe? of course you could NOT allow regen with a straight thru..
Sam
Old Aug 21, 2010 | 08:44 PM
jrc55's Avatar
jrc55
Half the 08-10's in my area including mine have black pipes.
Old Aug 21, 2010 | 08:45 PM
sdetweil's Avatar
sdetweil
Mine included.. just checked by ford.. all ok they say
Sam
Old Aug 22, 2010 | 02:16 PM
bnmccoy's Avatar
bnmccoy
Me too
Old Aug 22, 2010 | 02:37 PM
KC8QVO's Avatar
KC8QVO
A buddy at work did a DPF-delete and tuner on his 6.4L and it doesn't smoke a whole lot. If you are driving normally it doesn't put out any black, only when you step on it.
The problem with a "de-tuned" DPF is that the function of it is to trap particulate matter. The engine burns rich to begin with to keep the NOX emissions down then the DPF takes care of the particulates. If you knock out the functionality of the DPF you will be emitting more particulate matter. If you ever have any kind of exhaust test done by inspectors the high level of particulate matter would set them off to something being goofy.
Old Aug 22, 2010 | 02:48 PM
sdetweil's Avatar
sdetweil
no emissions test for diesel in austin
Sam
Old Aug 23, 2010 | 03:38 AM
Neil64's Avatar
Neil64
Hollowed out
Does anyone know of anyone hollowing out the DOC & DPF? I assume that is can be done without causing exhaust leaks like they they used to do back in the 70s and 80s when catalytic converters used to seriously degrade MPG and performance?
Old Aug 23, 2010 | 06:11 AM
ruschejj's Avatar
ruschejj
Well, back in early '08 some of us that just got 6.4's were hoping that in a few years somebody like Flowmaster or K&N would develop and market a direct replacement for the factory DPF promising less restriction, better exhaust flow, better MPG, etc....
Problem is, at the time, understanding that the PCM monitors backpressure and uses that information to determine the fueling of the injectors/EGR/regen. A low restriction DPF would foul all that up.
Ideally, an aftermarket DPF that would not require a PCM flash AND give a performance upgrade would be the ticket.
