when it ry to start up my engine it backfires out of the exhaust. then when it is idleing and i press the gas it backfires out of the carb. i have checked the timing, it is set right. i'm stumped on this one and i need some help.
Backfiring is almost always timing. Rarely ever is it a mechanical problem (though sometimes it's a timing problem created by a mechanical problem.. if that makes sense.) At some point you're getting a spark while an exhaust or intake valve is partially open. Your timing light may be showing you that everything is right on. If your cam is off a couple of teeth, you may not be and the light won't help figure that out.
Doublecheck for vacuum leaks. They can and will cause problems. If you don't have any, then I'd put it at top dead center, set the timing to 12 degrees and see how that works. If it still backfires, I'd be doublechecking the distributor to make sure there aren't any problems with it. I had a distributor that had a nasty habit of the rotor rising up and completely destroying the cap. It had problems keeping the timing set. Little wonder. Anyways, past that, the only place left to go is the timing chain and the cam/crank timing to ensure everything is straight up. If say, the cam is 180 degrees off there will be problems. Same for the crank.
thanks i'll try that when i get my radiator fixed. i got clumsy and drop a screw driver in and it hit the fan and flew into the radiator. boy i'm p/o about right now.
crap happens! especially when I get to work
springs shootin' outta the hood, dropping stuff in the wrong place,oil allover my parents driveway etc. allmost lost a
pencil in my cylinder head trying to measure stroke
try playing with the climate controll after you got the idle set,
if it has trouble stARTING or sounds too rich at cold start.
took it to the radiator shop today and they said it would be better to get a new one because the old one was not worth fixing. anybody got any suggestions on what kind to get.
No recomendations on a brand, but you want one with a good warranty. 5 years ago I shopped around, and at that time the best warranty I could find for the price was 3 years for a heavy duty one for my truck (3 row). It's still in there, and aside from the bugs stuck in it, it still looks relaitvely new!
