Sponsored by: Real Truck
idiot lights
Old Aug 20, 2010 | 07:39 PM
wescon's Avatar
wescon
idiot lights
alright so i fixed one problem on a 2003 ford f350 with 6.0 the pcm was fault creating no boost. Now the truck has lots of power but now there is a light on on the far right hand side of the cluster looks like a filter with 2 slanted lines on the left side and a areo pointing towards to passenger side i dont have the owners manual where can i find a site or if some one has a pic of all the idiot lights with names next to them but i am concerned with the one stated above if any one can find for me.
Old Aug 20, 2010 | 09:45 PM
jc8825's Avatar
jc8825
That is the air filter light. It is telling you that your air filter is clogged. It is found in the diesel supplement to your manual, not in the regular manual. Change the filter and reset the sensor. Funny too, if you look at the board inside the cluster for that LED it is labeled as "OIL CHANGE". I guess Ford was going to put in an oil change indicator but realized it would lead to more problems and just made it the filter light.
The manual states that it is okay to drive up to 250 miles with the light on without causing trouble.
Old Aug 20, 2010 | 10:14 PM
dchamberlain's Avatar
dchamberlain
You can download your owner's manual here...
https://www.flmowner.com/servlet/Con...ionalEventPage
The Diesel Supplement describes the operation of the Filter Minder and the Filter Minder warning light.
Old Aug 21, 2010 | 11:18 AM
wescon's Avatar
wescon
i thought it might be the filter light thank you.
Shadowrider123
Jun 3, 2015 09:38 AM
pecanguy
Aug 31, 2013 08:09 AM
foul1
Aug 25, 2013 07:29 PM
zukinut
13
Oct 9, 2011 02:46 PM
79F150400M
16
Dec 3, 2010 02:25 PM
