Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Hot Tranny!!!!!!
Old Sep 23, 2010 | 11:20 AM
perryg114's Avatar
perryg114
Ok that makes sense. In neutral or park it is still circulating oil but not generating much heat. I will look into the fan idea. I would have to mount the trans cooler in front of the AC condensor for sure if I did that. If I reved the motor a little in P or N that would help move some air as well.
Is there any danger of overcooling the transmission in the winter?
Perry
Old Sep 23, 2010 | 11:25 AM
perryg114's Avatar
perryg114
How does the F250 cooler differ from the 26 row 6.0L cooler?
Perry
Old Sep 23, 2010 | 08:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, that's possible. A piece of cardboard in front of the cooler will take care of that.
If the F250 is a 6.0L it is the 26 or 31 row cooler. Either one will do the job.
Old Sep 23, 2010 | 08:30 PM
perryg114's Avatar
perryg114
Well I put the thing on the Excursion tonight. I don't quite have all the hoses hooked up yet but it fit right in where the old one came out. The biggest pain was all those plastic mushroom connectors that hold all the baffles in place and especially the tinnerman nuts that held the cooler. I don't think overcooling is too much of an issue in Alabama but I will get a Scanguage just to make sure. How cool is too cool. The cooler I used is the 26 row cooler.
Perry
Old Sep 30, 2010 | 08:17 AM
perryg114's Avatar
perryg114
Word of wisdom. If you upgrade your cooler to a 6.0L cooler don't keep the factory pigtail on one side. Replace the hose and put a real screw type hose clamp on both ends of the cooler. Mine was leaking this morning when I got to work where the factory pigtail connected to the right side of the cooler. You would think the factory connection would not leak. I had to remove the lower bumper thing this morning at work and put another hose clamp on the cooler.
Perry
Old Jan 15, 2011 | 03:16 AM
johnbrown's Avatar
johnbrown
Hi,i have a 1995psd, my son's brother helped him put a trans. tempature gauge and that's when
we found out that the truck had been running up to 240 degrees for years and when it got
up there it would not come down so we added a large cooler from Shuck's now the temp's
are down to 180 degrees and stay there.
DDPJ
23
Apr 20, 2016 10:02 PM
JOE SKI
1997 - 2003 F150
Sep 13, 2014 09:15 AM
maldbwmjr
Sep 25, 2008 10:42 AM
johnsjsj
New Member Introductions
Mar 28, 2007 02:35 PM
Fedds3.0
Mar 23, 2006 04:13 PM
