97 F-150 TRANSMISSION FLUID CHANGE
I'm in the process of changing the tranny filter and fluid and am going to unbolt the tranny line going to the cooler. Which line pumps the fluid from the tranny to the cooler on a 4R70W transmission...the one on the drivers side or pass. side of the vehicle? I really don't want to unbolt the return line if I don't have to. I'll just pump out a quart or 2 at a time and add more as I go. Thanks
Pre 2001 had a torque converter with a drain plug in the bottom. You can rotate the flywheel with a large screw driver and get the plug on the bottom. You can get 5 quarts out of the trans pan, and 8 quarts out of the converter... don't need to remove the line and pump it out.
And I chalk or stick a piece of masking tape on the crankshaft pulley to get an idea how far I have turned it before I go look.
I used an 18 inch screw driver and pry 3-4 teeth at a time thru the bottom hole looking at the fly wheel. It don't turn that hard........... To refill, put in about 8 quarts, then start the motor and run 30 - 60 seconds. Put in 4 quarts and start it again... check the dip stick to see if you need a quart or more. Trans pump will fill the converter pretty quick.
on
Once you have it "full", start it, let it run for a minute or so, then shift it through the gears, leaving it in each gear for 10 seconds or so each way (R, N, D, 2, 1, 2, D, N, R then back to park). Check fluid and make sure it is in the "Full Cold" range. Get back in and go for a 10-15 minute drive with some moderate speeds then park it and check fluid again using the "Hot" range on the dipstick.
Guess I'm lazy, I added a drain plug to my pan, drain X amount of fluid in my spare time.....maybe 2/3 times a year and never have a problem.
May sound like a lot but it's that or watch tv.
---that is a good plan also for most new vehicles. IN the case of the pre 2001 F150 the converter has a drain plug on the converter and that makes it really simple for a one a one shot change. I use your plan on my Explorer--- once every 30K miles.
<!-- / message -->
<!-- / message -->
digger01
1997-2006 Expedition & Navigator
03-22-2005 10:31 PM
