2008 f250 Weight
I can finally add something to this forum. I have been lurking and learning. I have a 2010 F250 CC 2WD short bed and here are my numbers.
Weight (full tank, me and dog in truck):
Total 7680
Front Axle 4580
Back axle 3100
Weight of 15k Superglide hitch
180 plus mounting kit ... total about 210
Weight of DW
125
So total weight of Truck full of fuel, 5th wheel hitch, Dog, Me, and wife
is 8015.
GVWR is 9800 on truck is
So that leaves about 1800 for 5th wheel pin weight and cargo..
As mine is a 2 WD, I suppose that is why my numbers are a few hundred pounds less than yours...I have been told that 4WD adds 400+ pounds...
Here is a link to a discussion thread on my weight numbers:
F250 and Pin Weight Question - iRV2 Forums
Also google 3/4 ton towable 5th wheels and you will get a wealth of information and opions.
WR is weight on the tires..
GV says gross.. ie 'max'.. 10,000
your actual is 8220
so you have room for 1780 lbs of stuff in/on the truck.
now in that 10,000 Max, they say do NOT put more that 6000 on the front axle, and no more than 6100 on the rear axle. (don't get into adding these it'll drive u crazy)..
so, as part of the actual weight, they told you you currently have 3200 lbs on the rear axle.. so you technically COULD add 2900 to the rear axle.. BUT you are limited to a total of 1780 across the entire truck. by the GVWR..
so, take away another 1/2 tank of fuel and add another passenger.. 300lbs.. you can add 1480 worth of weight to the truck..
now.. onto the trailer.. the GCVWR say that the total weight on the ground (gross, not actual) is limited to 23000.
the truck is 10,000 already.. so the trailer cannot be more than 13000, total. and of that 13000 you cannot have more than 1480 of it sitting ON the truck. (pin)
now, one additional thing, most 5th/gn say that the pin should be 15-25% of the total weight of the trailer..
15% of 13000 is 1950.. this would be more than the 1480 we calculated above..
so, another way to calc trailer is if 1480 is 15%, what is 100%.. , approx 9866 lbs. at 25% its 5920.
so, I think the final net is
you CAN put more ON the rear axle (up to 2900)
and stay withing the axle rating, but it will put you over the vehicle rating. (at 2900 on the pin @ 25% the trailer would be 11600, and @ 15% 19300.. (way over the GC)..
so.. netted all out.. someplace between 9866 and 13000
with 15% on the pin.. but you probably be over the truck Gross Weight Rating.
they don't care what you ACTUALLY weigh, as long as it is UNDER the rated weight.
also, triple axle trailer will be a telltale sign that you are over.
cause the lowest, 5k axle times 3 is 15k.. and we said 13 was the limit..
also, not 'all' the weight of the pin will sit exactly on the rear axle.. there is some formula to guess the rear.front distribution, but I don't know it.
(net is 2900 of exact pin weight won't weigh as 2900 all on the rear axle itself)..
Sam
RV.Net Open Roads Forum: Whats Your Real Weights? Truck and Trailer. The Real Deal
10,000 seems to be the magic limit in some states. and 26000 is the magic combined number.. over you are 'clearly' commercial..
RV gets an exemption.
I want to pull a 44/48ft GN enclosed car hauler, to take my two show vehicles to shows around the country. but I cannot find a combination that works, and I don't get the exemption.
truck is 13000 GVWR, trailer has to be under 13000.. 2 6k axles is 12,500, but the two cars will put it overweight. 2-7k axles is 14+..
and now I'm over 26k, and need commercial license, insurance, etc..
all drivers..
now, I will admit that in the future these vehicles could represent advertising of my after retirement income generation, but not yet.
they are MY personal vehicles. so they are not for hire..
Sam
The reason I say this, my neighbor has 40 ft Monaco, with a 20 ft enclosed trailer, and his antique car. I towed just the trailer down to the scales and weighed it for him as he did not want to hook up the Pusher, it weighed in at 10,000 +lbs. His Pusher, loaded, his ticketed stated his weight was 32800 lbs. Added the 2 together is over 42k. The GCWR is 43,000. He has no commercial licensess whatsoever and has been doing this for over 15 years. Are we saying there are special commercial consideratons for our "Pickup" trucks where we have to have a commercial license when we go over certain weights? I understand the 23,000lbs total weight for the PU's but then I am hearing that anything over 26k needs a commercial licenses. I am having a problem with that for now.
Massachusetts - all dually must be commercial
https://www.ford-trucks.com/forums/9...ons-in-ma.html
NY over 10,000 must be commercial
https://www.ford-trucks.com/forums/9...al-plates.html
CA all pickups are commercial. (over 10k?)
https://www.ford-trucks.com/forums/6...ml#post4766089
https://www.ford-trucks.com/forums/9...ml#post9081320
https://www.ford-trucks.com/forums/8...ml#post7775098
etc..
RV's get exemption. cause they are clearly 'NOT commercial'
and if I put a toilet (as well as sleeping area) in my 48ft trailer I can 'claim' its rv.. but then lose the towing space too.!..
my auto ins company doesn't insure commercial.
and don't get all logical on us!.. and it doesn't matter what you DO weigh, only what your 'qualified' for.. (my truck is 13k, a 14k trailer will put me at 27k total.. even if empty I weigh 14k total
Sam
correct, not making money, and not for hire to carry anyone elses gear. so I would guess, only for the tax fees
here are the specs from dmv.org
CDL Classes for Every State
To be eligible for a CDL, you must have a clean driving record. Federal regulations require you to pass a physical exam every two years. To operate a commercial motor vehicle in interstate commerce, you must be at least 21. Many states allow those as young as 18 to drive commercial vehicles within the state. You must be able to read and speak English well enough to read road signs, prepare reports, and communicate with the public and with law enforcement.
The Act established three separate classes of commercial driver's licenses. Every state issues licenses in these categories:
- Class A: Any combination of vehicles with a gross vehicle weight rating (GWVR) of 26,001 or more pounds, provided the GVWR of the vehicle(s) being towed is in excess of 10,000 pounds.
- Class B: Any single vehicle with a GVWR of 26,001 or more pounds, or any such vehicle towing a vehicle not in excess of 10,000 pounds GVWR.
- Class C: Any single vehicle, or combination of vehicles, that does not meet the definition of Class A or Class B, but is either designed to transport 16 or more passengers, including the driver, or is placarded for hazardous materials.
Top Endorsements
To be licensed for certain types of commercial vehicles, extra testing is required. If you pass, you will receive an endorsement on your CDL. These are the five endorsements that you can apply for. Each requires between one and five knowledge (written) tests, and two require driving (skills) tests.
- T―Double/Triple Trailers (knowledge test only)
- P―Passenger (knowledge and skills tests)
- N―Tank Vehicle (knowledge test only)
- H―Hazardous Materials (knowledge test only)
- S―School Buses (knowledge and skills tests)
Top Requirements for Medical Certification
In the interest of public safety on the highways, Federal Motor Carrier Safety Administration (FMCSA) regulations require interstate commercial drivers to be medically fit to operate their vehicles safely and competently. You are required to have a physical exam and carry a U.S. Department of Transportation (DOT) medical certificate if:
- You operate a motor vehicle with a gross vehicle weight rating (GVWR) or gross combination weight rating (GCWR) or gross vehicle weight (GVW) or gross combination weight (GCW) of 4,536 kilograms (10,001 pounds) or more in interstate commerce.
- You operate a motor vehicle designed or used to transport more than 15 passengers, including the driver, in interstate commerce.
- You operate a motor vehicle designed or used to transport between nine and 15 passengers, for direct compensation, beyond 75 air miles from your regular work-reporting location, in interstate commerce.
- You transport hazardous materials in quantities requiring placards, in interstate commerce.
You must carry a current copy of your medical examination certificate with you when you drive. Residents of Mexico or Canada who drive in the United States can be certified by doctors in their countries, provided they meet the U.S. requirements.
Who is exempt from a CDL? (Certification form CDL-2
required)
Persons operating the following vehicles are exempt from a
Commercial Driver License:
- A vehicle that is controlled and operated by a farmer;
and used to transport agricultural products, farm machinery,
or farm supplies to or from a farm; and not used in
the operations of a common or contract motor carrier; and
used within 150 air miles of the person’s farm. - A fire-fighting or emergency vehicle necessary to the
preservation of life or property or the execution of emergency
governmental functions, whether operated by an
employee of a political subdivision or by a volunteer fire
fighter (this includes operators of industrial emergency
vehicles); - A military vehicle, when operated for military purposes
by military personnel, members of the Reserves and
National Guard on active duty, including personnel on
full-time National Guard duty, personnel on part-time
training, and National Guard military technicians; or - A recreational vehicle that is driven for personal use.
