Fuel tank pressure??
Old Aug 20, 2010 | 12:39 PM
tesseesman's Avatar
tesseesman
Hey all, i have a 96 f250 7.5 with dual tanks, when 1 or both tanks are full and truck sits out in the HOT sun all day it pushes gas past the cap, is some sort of vent plugged or simply a bad cap(s)? it is ok in cooler temps, very annoying cause of the odor, not losing quantities of gas, just some dampness around cap(s) and fumes of course, when tank is run down its fine.and mpg is awesome any ideas??
thanks for the help
Old Aug 21, 2010 | 08:16 AM
17Z's Avatar
17Z
Fuel expands when it's hot......going to go somewhere.
Either try not to fill the tanks up to the fill hole...or burn some off each tank when you fill. Shouldnt be an issue with a 460....they like gasoline!
Old Aug 21, 2010 | 10:51 AM
tesseesman's Avatar
tesseesman
i know that fuel expands when hot, but none of my other cars have ever done this, didnt know if anyone had seen this before and knew of a common problem, plugged vent or something? i guess winter time is coming soon enough right then it wont be an issue
Old Aug 21, 2010 | 04:01 PM
rosco_p_coltrane's Avatar
rosco_p_coltrane
I would check to see if all the lines to your evap system are in good shape and not kinked. Maybe theres something wrong with the canister purge solenoid, I would check that out.
Shadowrider123
Aug 9, 2014 04:25 PM
michael cook
2009 - 2014 F150
16
Dec 1, 2011 03:13 AM
popo1
Apr 6, 2010 07:01 AM
Zelhusker
13
Nov 20, 2007 03:20 AM
Jrmobb
Bronco II
Jan 13, 2004 12:09 AM
