Sponsored by: Real Truck
transferflow tanks???
Old Apr 5, 2010 | 02:24 AM
popo1's Avatar
popo1
Last week I had the stock gas tank removed and a 47 gal replacement tank installed. Now one week later and about 200 kms the gas cap indicator came on while I was driving to work. No problems at all getting to work and when I got there I checked the cap and it is in good shape and is on as well as it will go. My question, could this be cap related or can there be some problem with the tank install?
I was thinking about stopping at the dealer on the way home to book it in and have a look or should I go to the installer first.
The truck is a 2008 F-350 6.8L.
thanks for the help.
Old Apr 5, 2010 | 02:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
I would blame the tank first. Your first visit should be back to discuss the fuel incident with the installer.
Old Apr 5, 2010 | 04:26 PM
dynamic's Avatar
dynamic
check the gasket on the cap, it may have slide up the cap and isn't allowing a good seal. check the gas cap door for a mold looking film. If you have the film anywhere, you have a vapor leak coming from the gas cap.
Just finished fighting with the same issue!
Old Apr 5, 2010 | 07:12 PM
WestxSRT10's Avatar
WestxSRT10
I want the set-up you have....did it cost over $1200 installed?
Old Apr 5, 2010 | 07:36 PM
popo1's Avatar
popo1
It cost 1835 installed. That is up here in Canada where everything is more expensive regardless of how our dollar is doing. But it was worth it to not have to stop every couple of hours when towing, especially when going over the rockies when milage is a little worse and towns are spread out a little further.
As far as the gas cap, it looks like it was the rubber gasket was the issue. When I straightened it out the message went off.
Thanks for the tip saved me a trip to the installer.
Old Apr 6, 2010 | 07:01 AM
dynamic's Avatar
dynamic
Anytime! Glad that worked for you. I fought with my gas cap light and engine light for quite a while.
Don't forget the rep points!
papyjack
1978 - 1996 Big Bronco
Nov 17, 2019 07:42 PM
DirtyLarry79
Mar 14, 2017 06:11 PM
Pdxjacob
May 9, 2016 01:57 PM
Sportsterengr
Apr 18, 2016 02:29 PM
djmichael24951
Apr 1, 2016 07:48 PM
