What was I thinking?
Old Aug 22, 2010 | 08:41 AM
Lukes66's Avatar
Lukes66
Well I got my rear drums off and they are in good shape. The shoes aren't worn completely down, but they have turned to putty from being soaked with brake fluid. I can scrape bug wads of friction material off of the shoes with a fingernail. I picked up a new set of shoes, 2 new wheel cylinders and some brake kleen. I'm planning to clean, soak, and reuse the hardware. I will post up when I'm done. Then I will tear into the front brakes. I noticed yesterday that one of the rotors has 3 big cracks in it! I drove this thing 140 miles at 75 mph like this! I got lucky I guess.
Old Aug 22, 2010 | 09:16 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
you'll just have to inspect the self adjusters and stuff.make sure they all look good and work free.
yeah,one of my rotors cracked too so i replaced both.old metal and new heat don't mix i guess lol.
good time to replace all the brake line while your doing it.it doesn't cost much doing it yourself,but it all takes time.
sure beats chasing leaks latter or blowing a line when your trying to stop and get stranded......or worse.
Old Aug 22, 2010 | 11:38 AM
greywynd's Avatar
greywynd
Are you sure it's brake fluid and not gear lube from leaky rear seals?
Old Aug 22, 2010 | 01:55 PM
Lukes66's Avatar
Lukes66
I will check the wheel seals, I may need to replace them while I'm ion there. I'm going to order the rubber line for the rear axle but I'm not planning to replace the metal lines.
Old Aug 22, 2010 | 07:31 PM
Lukes66's Avatar
Lukes66
Do I need a special socket like this to replace wheel seals on my 10.25? Is there a way to do the job without buying the special tool?
Old Aug 22, 2010 | 09:47 PM
greywynd's Avatar
greywynd
Yes you need that socket, but you may be able to get it through a loan a tool or rental from some of the parts places. I think when I bought mine it was was about $25 though, and something you may need again sometime.
DBD7
19
Jan 9, 2014 11:54 PM
Lukes66
16
May 11, 2011 07:57 PM
superduty4x4
68
Nov 19, 2008 01:09 PM
luke-gr
16
Apr 25, 2007 10:05 PM
Lukes66
Apr 7, 2003 12:45 PM
