hey guys. im a idi forum guy lookin for some help on a 71 bronco. i know you guys are bronco 2 guys.... lookin to buy a cheap bronco 2 with a v6 and swap the engine, tranny and tc into the 71. how do you v6 guys do on power, fuel, reliability? anything i should stay away from? look for? thanks for the help
well i would say honestly that the 2.9 v6 which comes in the b2's may be underpowered for your application...they are realiable but they dont hav much gumption in b2's...if i were you grab a 300-6 and throw it in...they will give you about 20mpgs maybe more.. and they are limitless on torque...just my thought..
Bronco II's had the 2.8 and 2.9 v-6's. The 2.8 was carbed and has been said to be a higher rpm engine. The 2.9 is fuel injected and has more torque. Transmissions had problems in both. The A4LD does well in stock form with a good auxl cooler but I have not had any luck with rebuilds. They just seem to last the 12 month waranity and are bad again. The c-5 in the early 2.8 has trouble with off the shelf converters. If you do a search on this site and other BII sites you will find threads where folks try to adapt a v-8 converter. I am running a c-5 and doubler(second low range box) in my 88 behind a 2.9 and was able to get a good converther from a converter builder after problems with two off the shelf parts house converters.
Are you looking for a carb application? If not I would think the 4.0 would be a better choice than the old 2.9.
thanks for the info. since the guts are for a 71 standard bronco maybe ill just try to find a wrecked full size 78+ or pickup and rob it of its goods. its just hard to pass up how cheap the bronco II's are. thanks agian
I have a 4.0 in my B2, still get 17mpg. My foot is a little heavy.. I'd say get a 1st gen explorer. They are readily available, cheap and the 4.0 is an awesome little v6
